Date/Time: Sun, 24 Nov 2024 02:24:30 +0000
bracket order placed - shows Live - then cancels itself a couple of minutes later
View Count: 1212
[2013-09-11 15:59:43] |
snillumat - Posts: 29 |
Ive had this problem randomly occur when using SC for order entry for OEC. It's rare and random but extremely frustrating. Is it possible for SC support to research a specific/individual trade problem or is it just "one of those software bugs" that I need to live with?
[2013-09-11 21:05:38] |
It is definitely not a bug on our side. There is definitely a reason for it and it would have to do with connectivity to the server or a problem on the OEC side. We need to see the lines for this order in the Trade Activity Log. Follow these instructions: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php At the top of the Trade Activity Log, set it to display All Activity. We will look at the log and see what happened. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-11 21:05:56
