Date/Time: Thu, 16 Jan 2025 12:10:31 +0000
Orders no filled on simulated account
View Count: 548
[2017-11-02 09:56:47] |
UserZiltoid - Posts: 57 |
Hello, I have set several orders in the simulated account (using DCP protocol). non of the orders were filled. I put values higher then the market price, and still nothing. See attached screen shots. |
Private File Private File Private File |
[2017-11-02 10:05:57] |
It appears as though you have not set the BuySell field of the order.
[2017-11-02 13:14:33] |
Thanks, I sent by mistake the ENUM values instead of the INT values.
