Date/Time: Thu, 16 Jan 2025 12:19:51 +0000
how to add buttons for multiple drawn volume profiles
View Count: 561
[2017-11-01 22:23:13] |
User339031 - Posts: 5 |
Hi, I use drawn volume profiles with different configurations and would like to have several buttons on a toolbar to correspond to these configurations. I can see how to add a single button corresponding to one of these, but haven't been able to figure out how to add a 2nd one. Please let me know how to do this. Thanks |
[2017-11-02 02:37:53] |
Refer to the instructions here: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-02 02:38:05
