Date/Time: Thu, 16 Jan 2025 12:02:21 +0000
custom colors
View Count: 749
[2017-11-01 21:53:26]
User163689 - Posts: 29
Trying to add some custom colors to certain things and save the colors. When i try to save to custom color it only saves the last one and wont delete older colors to replace with newer, so essentially i can only save 1 color Is there a way to delete the older colors?
[2017-11-02 04:50:11]
You are not following the correct procedure then.
Follow the instructions here:
Graphics Settings: Setting Default Custom Colors
