Date/Time: Thu, 16 Jan 2025 10:42:52 +0000
projecting a few ticks
View Count: 706
[2017-11-01 10:25:50] |
user8888 - Posts: 159 |
Hello, How could I draw an extension of, say, 10 ticks from a certain price/time? I've been trying with the 'Study Subgraph Add' but it does not seem to consider a concrete number of ticks as the 'Amount to add'. Is there another study for accomplish this? Thanks much for your help |
[2017-11-01 18:21:00] |
Sounds like you will want to use the Horizontal Line at Time study: Horizontal Line at Time And use Study Subgraph Add based on it. For the actual value to use, simply multiply 10 times the tick size. You can determine the tick size through Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
