Date/Time: Thu, 16 Jan 2025 16:18:29 +0000
POIV
View Count: 3410
[2017-11-01 10:15:33] |
User851573 - Posts: 16 |
Hallo, I would like to know, if is POIV from Larry Williams available in Sierra Chart? What is the name of this indicator in Sierra Cahart? Thank you in advance for the response Dusak |
[2017-11-01 16:47:45] |
What does POIV stand for?
[2017-11-01 16:57:59] |
Price, Open Interest and Volume = POIV constructed by Larry Williams. Do you have this or something very similar?
[2017-11-01 18:04:20] |
Do you know what the formula is in relation to those particular values?
[2017-11-02 06:42:39] |
in the middle of this article....http://www.futuresmag.com/2007/11/14/all-one-price-volume-and-open-interest CumulativeSum (Open Interest * (Close - Close.1) / (True High - True Low)) + OBV |
[2017-11-03 02:32:12] |
We are adding this study now.
[2017-11-05 12:35:02] |
What is the name of the study?...I cannot find it in Studies...
[2017-11-05 17:07:37] |
It is in the latest release and called: Price, Open Interest and Volume
[2017-11-06 08:31:32] |
Thank you, but it does not work ...see enclosure 1 I need to see like this...line in graph...see enclosure 2 ...poiv by Larry |
POIV ropa.png / V - Attached On 2017-11-06 08:27:13 UTC - Size: 17.52 KB - 512 views poiv by larry.png / V - Attached On 2017-11-06 08:30:36 UTC - Size: 243.27 KB - 553 views |
[2017-11-06 08:46:51] |
OK this is because there was a zero being used in a division causing an error. These divisions will be filtered out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-06 08:59:41] |
When do you expect new release? Will POIV be line in graph?
[2017-11-06 18:11:23] |
Should be out in another day or two. You can display the study anyway you want. Refer to the documentation here: Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-09 19:34:48] |
There is some mistake in the POIV line...I do not know why. Original POIV shows quite different line...
[2017-11-09 20:40:28] |
The study can only be used on Historical Daily charts that have open interest data. Here is how it is calculated: sc.OnBalanceVolume(sc.BaseDataIn, Array_OBV);
float TrueHighLowDifference = sc.GetTrueHigh(sc.BaseDataIn) - sc.GetTrueLow(sc.BaseDataIn); if (TrueHighLowDifference != 0) { Array_IntermediateCalculation[sc.Index] = ( (sc.BaseDataIn[SC_OPEN_INTEREST][sc.Index] * (sc.BaseDataIn[SC_LAST][sc.Index] - sc.BaseDataIn[SC_LAST][sc.Index - 1]) ) / TrueHighLowDifference ) + Array_OBV[sc.Index]; sc.CumulativeSummation(Array_IntermediateCalculation, Subgraph_POIV); } else { Subgraph_POIV[sc.Index] = Subgraph_POIV[sc.Index - 1]; } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
