Date/Time: Sun, 24 Nov 2024 02:55:41 +0000
Smart Key?
View Count: 1397
[2013-09-11 14:45:50] |
User93103 - Posts: 48 |
Hello: Is there a smart key (one click) for entering or exiting a trade on SIERRA DOM? That is, one does not need to click on the selected Sell or Buy column and then OK it. God Bless Ben |
[2013-09-11 15:13:24] |
Yes. Simply disable order confirmations. Refer to this section: https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
