Date/Time: Thu, 16 Jan 2025 16:22:20 +0000
Trading Info File
View Count: 963
[2017-10-31 16:05:04]
jizzary - Posts: 177
Hi
Is there any way a user can construct a trading info file (.dly, .scid)
with testing info so that Sierra platform can read and "play" it (i.e. replay/present)?
Maybe you have a utility that takes a CSV file and pushes it the trading info file ?
Please advise. Thanks.
[2017-10-31 18:15:24]
There is a way to do this through these functions but they are not documented:
int (SCDLLCALL* RelayNewSymbol)(SCString Symbol, int ValueFormat, float TickSize, const char* ServiceCode);
  int (SCDLLCALL* RelayTradeUpdate)(SCString Symbol, double DateTime, float TradeValue, unsigned int TradeVolume);
[2017-10-31 20:49:53]
can you please send an example program (with input file example) plus some information
as for what should I expect as output or any other info which will help me using these APIs?
Looking at the APIs I don't think I have enough info to use it.
Many thanks.
Date Time Of Last Edit: 2017-10-31 21:19:09
[2017-11-06 23:53:01]
Documentation is still pending.
[2017-11-07 14:10:14]
Sorry .. unclear.
Is the documentation pending or the task םכ documentation גקהקךםפצקמא is pending?
when will be available?
Date Time Of Last Edit: 2017-11-07 21:25:53
[2017-11-09 20:35:12]
Here is the relevant documentation:
sc.RelayNewSymbol()
Make sure you are on the current version of Sierra Chart.
