Date/Time: Thu, 16 Jan 2025 11:00:10 +0000
default displayed sheet on scss spreadsheet open
View Count: 950
[2017-10-31 15:04:00] |
User316362 - Posts: 210 |
Is there a way to control the sheet that is displayed on open of a spreadsheet (scss) using the Spreadsheet Study? Setting the default displayed "Sheet" on open if you will. I have to change the sheet to my customized display sheet every time Sierra restarts. Would be a nice feature if there is no way. Date Time Of Last Edit: 2017-10-31 17:17:37
[2017-10-31 18:16:07] |
Do you have multiple Spreadsheet Studies using the same Spreadsheet file?
[2017-10-31 19:34:01] |
Sawtooth - Posts: 4153 |
+1I have to change the sheet to my customized display sheet every time Sierra restarts. Would be a nice feature if there is no way. At least return to the last sheet viewed since the file was saved. Date Time Of Last Edit: 2017-10-31 19:37:10
[2017-10-31 20:03:11] |
no, only one spreadsheet study uses the file. And I tested for Attached /detached spreadsheet conditions also. Same result, when i restart the (or close and open the chart book) the spreadsheet defaults to the data sheet
Date Time Of Last Edit: 2017-10-31 20:05:09
[2017-10-31 21:16:07] |
when i restart the (or close and open the chart book) the spreadsheet defaults to the data sheet Yes this will be the case. This cannot be changed.
