Date/Time: Thu, 16 Jan 2025 11:06:31 +0000
Disconnect to Data Feed
View Count: 940
[2017-10-31 13:58:26] |
User609896 - Posts: 7 |
Rithmic Trading | Port for executable: 58391 | 2017-10-31 08:29:53 Listening socket (668). Port 58391 | Closed. | 2017-10-31 08:29:53 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:53 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58391 | 2017-10-31 08:29:55 DTC Client socket (24) | Creating socket. | 2017-10-31 08:29:55 DTC Client socket (24) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:55 DTC Client socket (24) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:56 * DTC Client socket (24) | Initiating close of socket by core. | 2017-10-31 08:29:56 DTC Client socket (24) | Closed. | 2017-10-31 08:29:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:56 Rithmic Trading | Disconnected. | 2017-10-31 08:29:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:56 File >> Disconnect selected. | 2017-10-31 08:29:56 Rithmic Trading | Disconnected. | 2017-10-31 08:29:56 DTC Client socket (20) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 08:29:57 * DTC Client socket (20) | Socket gracefully closed by remote side. | 2017-10-31 08:29:57 DTC Client socket (20) | Closed. | 2017-10-31 08:29:57 |
[2017-10-31 16:52:21] |
We need to see the entire Message Log. Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-31 17:11:40] |
Reading Internal Order ID file. | 2017-10-31 08:28:21 Reading Trade Orders file. | 2017-10-31 08:28:21 Reading Trade Positions file. | 2017-10-31 08:28:21 Listening on UDP port 22903. | 2017-10-31 08:28:21 Software version: 1628 | 2017-10-31 08:28:21 Enabled for: Advanced Features. | 2017-10-31 08:28:21 Enabled for: Advanced Features 2. | 2017-10-31 08:28:21 Enabled for: Sierra Chart Historical Data Service. | 2017-10-31 08:28:21 Allow Support for Sierra Chart Data Feeds is disabled. | 2017-10-31 08:28:21 Current selected Data/Trading service: CQG FIX Trading | 2017-10-31 08:28:21 Chart Update Interval: 500 | 2017-10-31 08:28:21 Data/Trade Service Settings automatically set. | 2017-10-31 08:28:21 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-31 08:28:21 2017-10-31 14:28:25 Local computer time | 2017-10-31 08:28:21 2017-10-31 13:28:25 Local computer time in UTC | 2017-10-31 08:28:21 2017-10-31 08:28:25 Local computer time in SC Time Zone | 2017-10-31 08:28:21 2017-10-31 13:28:27 Server time in UTC | 2017-10-31 08:28:21 Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-10-31 08:28:21 Program path: C:\SierraChart\ | 2017-10-31 08:28:21 Data Files path: C:\SierraChart\Data\ | 2017-10-31 08:28:21 OS Version Number: 6.1 | 2017-10-31 08:28:21 Locale Setting: C | 2017-10-31 08:28:21 Checking for new symbol settings for service code cqg | 2017-10-31 08:28:21 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-31 08:28:21 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-31 08:28:21 Received 5 login tokens. | 2017-10-31 08:28:26 Requesting symbol settings for service code cqg. Overwrite = on. | 2017-10-31 08:28:26 Symbol settings received. | 2017-10-31 08:28:27 Processed 1194 symbol settings. | 2017-10-31 08:28:27 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-31 08:28:28 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-31 08:28:28 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-31 08:28:31 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-31 08:28:31 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-31 08:28:31 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-31 08:28:31 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-31 08:28:31 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-31 08:28:32 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-31 08:28:32 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-31 08:28:32 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-31 08:28:32 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-31 08:28:32 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-10-31 08:28:33 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-10-31 08:28:33 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-31 08:28:33 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-31 08:28:33 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-31 08:28:33 Files to Open on Start up | File does not exist: C:\SierraChart\Data\Chartbook2.cht | 2017-10-31 08:28:34 Checking for new symbol settings for service code rim | 2017-10-31 08:28:36 Current selected Data/Trading service: Rithmic Trading | 2017-10-31 08:28:36 HTTPS connection to www.sierrachart.com:443 (6) | Creating socket. Using TLS 1.2. | 2017-10-31 08:28:36 HTTPS connection to www.sierrachart.com:443 (6) | Connecting to IP: 204.15.192.108. | 2017-10-31 08:28:36 Rithmic Trading | Port for executable: 55408 | 2017-10-31 08:28:36 Listening socket (876). Port 55408 | Closed. | 2017-10-31 08:28:36 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:28:36 Requesting symbol settings for service code rim. Overwrite = on. | 2017-10-31 08:28:36 Symbol settings received. | 2017-10-31 08:28:37 Processed 1054 symbol settings. | 2017-10-31 08:28:37 Rithmic Trading | Bridge process is running. | 2017-10-31 08:28:39 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55408 | 2017-10-31 08:28:39 DTC Client socket (7) | Creating socket. | 2017-10-31 08:28:39 DTC Client socket (7) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:28:39 Rithmic Trading | Connected to server. | 2017-10-31 08:28:39 Rithmic Trading | Starting socket receive thread. | 2017-10-31 08:28:39 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 08:28:39 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 08:28:39 Rithmic Trading | Sending logon request message. | 2017-10-31 08:28:39 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 08:28:39 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 08:28:39 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 08:28:39 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 08:28:40 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 08:28:40 Rithmic Trading | Received logon response. | 2017-10-31 08:28:40 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 08:28:40 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 08:28:40 Rithmic Trading | Logon error received from server | 2017-10-31 08:28:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:28:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:28:40 DTC Client socket (7) | Initiating close of socket by core. | 2017-10-31 08:28:40 Rithmic Trading | Disconnected. | 2017-10-31 08:28:40 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:28:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:28:40 HTTPS connection to www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2017-10-31 08:28:42 HTTPS connection to www.sierrachart.com:443 (6) | Received socket Close event. | 2017-10-31 08:28:42 HTTPS connection to www.sierrachart.com:443 (6) | Initiating close of socket by core. | 2017-10-31 08:28:42 HTTPS connection to www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-31 08:28:42 HTTPS connection to www.sierrachart.com:443 (6) | Closed. | 2017-10-31 08:28:42 Rithmic Trading | Port for executable: 55420 | 2017-10-31 08:28:42 Listening socket (780). Port 55420 | Closed. | 2017-10-31 08:28:42 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:28:42 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:28:44 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55420 | 2017-10-31 08:28:44 DTC Client socket (8) | Creating socket. | 2017-10-31 08:28:44 DTC Client socket (8) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:28:44 DTC Client socket (8) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:28:45 * DTC Client socket (8) | Initiating close of socket by core. | 2017-10-31 08:28:45 DTC Client socket (8) | Closed. | 2017-10-31 08:28:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:28:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:28:45 Rithmic Trading | Disconnected. | 2017-10-31 08:28:45 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:28:45 Rithmic Trading | Port for executable: 55423 | 2017-10-31 08:28:47 Listening socket (880). Port 55423 | Closed. | 2017-10-31 08:28:47 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:28:47 NQZ7-CME 2 Min #6 | Reloading chart. | 2017-10-31 08:28:49 ESZ7-CME 2 Min #1 | Reloading chart. | 2017-10-31 08:28:49 YMZ7-CBOT 2 Min #3 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 1 Sec #4 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 2 Min #2 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 15 Min #8 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 15 Min #13 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 15 Min #5 | Reloading chart. | 2017-10-31 08:28:49 EMDZ7-CME 2 Min #7 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 2 Min #9 | Reloading chart. | 2017-10-31 08:28:49 NQZ7-CME 2 Min #10 | Reloading chart. | 2017-10-31 08:28:49 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-31 08:28:56 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ7-CME | 2017-10-31 08:28:56 Intraday data recording state for symbol NQZ7-CME is set to download 'Pending'. | 2017-10-31 08:28:56 HD Request # 2 | Downloading Intraday chart data for NQZ7-CME to the file NQZ7-CME.scid. Service: cme | 2017-10-31 08:28:56 HD Request # 2 | Download start date-time: 2017-10-31 01:46:23.000 | 2017-10-31 08:28:56 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2017-10-31 08:28:56 Socket (9) | Creating socket. | 2017-10-31 08:28:56 Socket (9) | Connecting to IP: 8.18.161.133. | 2017-10-31 08:28:56 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-31 08:28:56 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESZ7-CME | 2017-10-31 08:28:56 Intraday data recording state for symbol ESZ7-CME is set to download 'Pending'. | 2017-10-31 08:28:56 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:28:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55423 | 2017-10-31 08:28:56 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM?#-CBOT pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-31 08:28:56 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMZ7-CBOT | 2017-10-31 08:28:56 Intraday data recording state for symbol YMZ7-CBOT is set to download 'Pending'. | 2017-10-31 08:28:56 DTC Client socket (10) | Creating socket. | 2017-10-31 08:28:56 DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:28:56 'Allow Support for Sierra Chart Data Feeds' is disabled. The EMD?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-31 08:28:56 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: EMDZ7-CME | 2017-10-31 08:28:56 Intraday data recording state for symbol EMDZ7-CME is set to download 'Pending'. | 2017-10-31 08:28:56 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-10-31 08:28:56 HD Request # 2 | Sending historical data logon request message. | 2017-10-31 08:28:56 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-10-31 01:46:23. Record interval: 0. Symbol: NQZ17 | 2017-10-31 08:28:56 HD Request # 2 | Decompressing data. | 2017-10-31 08:28:56 DTC Client socket (10) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:28:56 * HD Request # 2 | Receiving Intraday data for NQZ7-CME starting at 2017-10-31 01:46:23 | 2017-10-31 08:28:56 DTC Client socket (10) | Initiating close of socket by core. | 2017-10-31 08:28:56 DTC Client socket (10) | Closed. | 2017-10-31 08:28:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:28:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:28:56 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-10-31 01:47:39 | 2017-10-31 08:28:56 Rithmic Trading | Disconnected. | 2017-10-31 08:28:59 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:28:59 Socket (9) | Initiating close of socket by core. | 2017-10-31 08:28:59 HD Request # 2 | Historical data for NQZ7-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-10-31 08:28:59 Historical data download thread signaled to stop. | 2017-10-31 08:28:59 HD Request # 2 | Received 12459 records from 2017-10-31 01:46:23 to 2017-10-31 08:18:59 (6.5 hours) and wrote 12458 records for NQZ7-CME | 2017-10-31 08:28:59 HD Request # 2 | Intraday download COMPLETE for NQZ7-CME. Completion time: 4s. Unique request ID: 1 | 2017-10-31 08:28:59 Removed historical data download ID 1 | 2017-10-31 08:28:59 Rithmic Trading | Using primary service for historical data for NQZ7-CME | 2017-10-31 08:28:59 Historical data service client indicated that downloads are not enabled. Symbol: NQZ7-CME. Data Type: Intraday data | 2017-10-31 08:28:59 HD Request # 2 | Download from primary service not started due to error. | 2017-10-31 08:28:59 HD Request # 3 | Downloading Intraday chart data for ESZ7-CME to the file ESZ7-CME.scid. Service: cme | 2017-10-31 08:28:59 HD Request # 3 | Download start date-time: 2017-10-31 01:46:55.000 | 2017-10-31 08:28:59 HD Request # 3 | Using server: ds1.sierracharts.com port 10150 | 2017-10-31 08:28:59 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:28:59 Socket (11) | Creating socket. | 2017-10-31 08:28:59 Socket (11) | Connecting to IP: 8.18.161.135. | 2017-10-31 08:28:59 Socket (9) | Socket gracefully closed by remote side. | 2017-10-31 08:28:59 Socket (9) | Closed. | 2017-10-31 08:28:59 HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-10-31 08:28:59 HD Request # 3 | Sending historical data logon request message. | 2017-10-31 08:28:59 HD Request # 3 | Requesting Intraday data. Start date-time: 2017-10-31 01:46:55. Record interval: 0. Symbol: ESZ17 | 2017-10-31 08:29:00 HD Request # 3 | Decompressing data. | 2017-10-31 08:29:00 HD Request # 3 | Receiving Intraday data for ESZ7-CME starting at 2017-10-31 01:46:55 | 2017-10-31 08:29:01 HD Request # 3 | Timestamp of first Intraday data file record written: 2017-10-31 01:48:35 | 2017-10-31 08:29:01 HD Request # 3 | Historical data for ESZ7-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-10-31 08:29:01 Socket (11) | Initiating close of socket by core. | 2017-10-31 08:29:01 Historical data download thread signaled to stop. | 2017-10-31 08:29:01 Socket (11) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:29:01 HD Request # 3 | Received 18695 records from 2017-10-31 01:46:55 to 2017-10-31 08:18:59 (6.5 hours) and wrote 18693 records for ESZ7-CME | 2017-10-31 08:29:01 HD Request # 3 | Intraday download COMPLETE for ESZ7-CME. Completion time: 2s. Unique request ID: 2 | 2017-10-31 08:29:01 Removed historical data download ID 2 | 2017-10-31 08:29:01 Rithmic Trading | Using primary service for historical data for ESZ7-CME | 2017-10-31 08:29:01 Historical data service client indicated that downloads are not enabled. Symbol: ESZ7-CME. Data Type: Intraday data | 2017-10-31 08:29:01 HD Request # 3 | Download from primary service not started due to error. | 2017-10-31 08:29:01 HD Request # 4 | Downloading Intraday chart data for YMZ7-CBOT to the file YMZ7-CBOT.scid. Service: cbot | 2017-10-31 08:29:01 HD Request # 4 | Download start date-time: 2017-10-31 01:46:49.000 | 2017-10-31 08:29:01 HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2017-10-31 08:29:01 Socket (12) | Creating socket. | 2017-10-31 08:29:01 Socket (12) | Connecting to IP: 8.18.161.133. | 2017-10-31 08:29:01 Rithmic Trading | Port for executable: 55430 | 2017-10-31 08:29:01 Listening socket (984). Port 55430 | Closed. | 2017-10-31 08:29:01 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:01 Socket (11) | Socket gracefully closed by remote side. | 2017-10-31 08:29:01 Socket (11) | Closed. | 2017-10-31 08:29:01 HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-10-31 08:29:01 HD Request # 4 | Sending historical data logon request message. | 2017-10-31 08:29:01 HD Request # 4 | Requesting Intraday data. Start date-time: 2017-10-31 01:46:49. Record interval: 0. Symbol: YMZ17 | 2017-10-31 08:29:01 HD Request # 4 | Decompressing data. | 2017-10-31 08:29:01 HD Request # 4 | Receiving Intraday data for YMZ7-CBOT starting at 2017-10-31 01:46:49 | 2017-10-31 08:29:02 HD Request # 4 | Timestamp of first Intraday data file record written: 2017-10-31 01:47:58 | 2017-10-31 08:29:02 HD Request # 4 | Historical data for YMZ7-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-10-31 08:29:02 Socket (12) | Initiating close of socket by core. | 2017-10-31 08:29:02 Socket (12) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:29:02 Historical data download thread signaled to stop. | 2017-10-31 08:29:02 HD Request # 4 | Received 9069 records from 2017-10-31 01:46:49 to 2017-10-31 08:18:44 (6.5 hours) and wrote 9068 records for YMZ7-CBOT | 2017-10-31 08:29:02 HD Request # 4 | Intraday download COMPLETE for YMZ7-CBOT. Completion time: 1s. Unique request ID: 3 | 2017-10-31 08:29:02 Removed historical data download ID 3 | 2017-10-31 08:29:02 Rithmic Trading | Using primary service for historical data for YMZ7-CBOT | 2017-10-31 08:29:02 Historical data service client indicated that downloads are not enabled. Symbol: YMZ7-CBOT. Data Type: Intraday data | 2017-10-31 08:29:02 HD Request # 4 | Download from primary service not started due to error. | 2017-10-31 08:29:02 HD Request # 5 | Downloading Intraday chart data for EMDZ7-CME to the file EMDZ7-CME.scid. Service: cme | 2017-10-31 08:29:02 HD Request # 5 | Download start date-time: 2017-10-31 01:37:19.000 | 2017-10-31 08:29:02 HD Request # 5 | Using server: ds1.sierracharts.com port 10150 | 2017-10-31 08:29:02 DTC Client socket (7) | Socket gracefully closed by remote side. | 2017-10-31 08:29:03 DTC Client socket (7) | Closed. | 2017-10-31 08:29:03 Socket (13) | Creating socket. | 2017-10-31 08:29:03 Socket (13) | Connecting to IP: 8.18.161.135. | 2017-10-31 08:29:03 HD Request # 5 | Setting DTC encoding to Binary VLS | 2017-10-31 08:29:03 HD Request # 5 | Sending historical data logon request message. | 2017-10-31 08:29:03 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:03 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55430 | 2017-10-31 08:29:03 DTC Client socket (14) | Creating socket. | 2017-10-31 08:29:03 DTC Client socket (14) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:03 HD Request # 5 | Requesting Intraday data. Start date-time: 2017-10-31 01:37:19. Record interval: 0. Symbol: EMDZ17 | 2017-10-31 08:29:03 HD Request # 5 | Decompressing data. | 2017-10-31 08:29:03 HD Request # 5 | Receiving Intraday data for EMDZ7-CME starting at 2017-10-31 01:37:19 | 2017-10-31 08:29:03 HD Request # 5 | Timestamp of first Intraday data file record written: 2017-10-31 02:16:00 | 2017-10-31 08:29:03 Socket (13) | Initiating close of socket by core. | 2017-10-31 08:29:03 Socket (13) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:29:03 HD Request # 5 | Historical data for EMDZ7-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-10-31 08:29:03 Historical data download thread signaled to stop. | 2017-10-31 08:29:03 HD Request # 5 | Received 315 records from 2017-10-31 01:37:19 to 2017-10-31 08:17:54 (6.7 hours) and wrote 314 records for EMDZ7-CME | 2017-10-31 08:29:03 HD Request # 5 | Intraday download COMPLETE for EMDZ7-CME. Completion time: 0s. Unique request ID: 4 | 2017-10-31 08:29:03 Removed historical data download ID 4 | 2017-10-31 08:29:03 Rithmic Trading | Using primary service for historical data for EMDZ7-CME | 2017-10-31 08:29:03 Historical data service client indicated that downloads are not enabled. Symbol: EMDZ7-CME. Data Type: Intraday data | 2017-10-31 08:29:03 HD Request # 5 | Download from primary service not started due to error. | 2017-10-31 08:29:03 Socket (13) | Socket gracefully closed by remote side. | 2017-10-31 08:29:04 Socket (13) | Closed. | 2017-10-31 08:29:04 DTC Client socket (14) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:04 * DTC Client socket (14) | Initiating close of socket by core. | 2017-10-31 08:29:04 DTC Client socket (14) | Closed. | 2017-10-31 08:29:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:04 Rithmic Trading | Disconnected. | 2017-10-31 08:29:04 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:04 Rithmic Trading | Port for executable: 55434 | 2017-10-31 08:29:06 Listening socket (928). Port 55434 | Closed. | 2017-10-31 08:29:06 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:06 Rithmic Trading | Bridge process is running. | 2017-10-31 08:29:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55434 | 2017-10-31 08:29:08 DTC Client socket (15) | Creating socket. | 2017-10-31 08:29:08 DTC Client socket (15) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:08 Rithmic Trading | Connected to server. | 2017-10-31 08:29:08 Rithmic Trading | Starting socket receive thread. | 2017-10-31 08:29:08 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 08:29:08 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 08:29:08 Rithmic Trading | Sending logon request message. | 2017-10-31 08:29:08 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 08:29:08 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 08:29:08 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 08:29:08 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 08:29:10 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 08:29:10 Rithmic Trading | Received logon response. | 2017-10-31 08:29:10 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 08:29:10 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 08:29:10 Rithmic Trading | Logon error received from server | 2017-10-31 08:29:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:10 DTC Client socket (15) | Initiating close of socket by core. | 2017-10-31 08:29:10 DTC Client socket (15) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:29:10 Rithmic Trading | Disconnected. | 2017-10-31 08:29:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:10 Rithmic Trading | Port for executable: 55444 | 2017-10-31 08:29:12 Listening socket (748). Port 55444 | Closed. | 2017-10-31 08:29:12 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:12 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:14 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55444 | 2017-10-31 08:29:14 DTC Client socket (16) | Creating socket. | 2017-10-31 08:29:14 DTC Client socket (16) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:14 DTC Client socket (16) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:15 * DTC Client socket (16) | Initiating close of socket by core. | 2017-10-31 08:29:15 DTC Client socket (16) | Closed. | 2017-10-31 08:29:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:15 Rithmic Trading | Disconnected. | 2017-10-31 08:29:15 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:15 Rithmic Trading | Port for executable: 55446 | 2017-10-31 08:29:17 Listening socket (972). Port 55446 | Closed. | 2017-10-31 08:29:17 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:17 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:19 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55446 | 2017-10-31 08:29:19 DTC Client socket (17) | Creating socket. | 2017-10-31 08:29:19 DTC Client socket (17) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:19 DTC Client socket (17) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:20 * DTC Client socket (17) | Initiating close of socket by core. | 2017-10-31 08:29:20 DTC Client socket (17) | Closed. | 2017-10-31 08:29:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:20 Rithmic Trading | Disconnected. | 2017-10-31 08:29:20 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:20 Rithmic Trading | Port for executable: 55449 | 2017-10-31 08:29:22 Listening socket (680). Port 55449 | Closed. | 2017-10-31 08:29:22 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:22 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:24 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55449 | 2017-10-31 08:29:24 DTC Client socket (18) | Creating socket. | 2017-10-31 08:29:24 DTC Client socket (18) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:24 DTC Client socket (18) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:25 * DTC Client socket (18) | Initiating close of socket by core. | 2017-10-31 08:29:25 DTC Client socket (18) | Closed. | 2017-10-31 08:29:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:25 Rithmic Trading | Disconnected. | 2017-10-31 08:29:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:25 Socket (12) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 08:29:25 * Socket (12) | Socket gracefully closed by remote side. | 2017-10-31 08:29:25 Socket (12) | Closed. | 2017-10-31 08:29:25 Rithmic Trading | Port for executable: 55451 | 2017-10-31 08:29:27 Listening socket (780). Port 55451 | Closed. | 2017-10-31 08:29:27 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:27 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55451 | 2017-10-31 08:29:29 DTC Client socket (19) | Creating socket. | 2017-10-31 08:29:29 DTC Client socket (19) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:29 DTC Client socket (19) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:30 * DTC Client socket (19) | Initiating close of socket by core. | 2017-10-31 08:29:30 DTC Client socket (19) | Closed. | 2017-10-31 08:29:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:30 Rithmic Trading | Disconnected. | 2017-10-31 08:29:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:30 DTC Client socket (15) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 08:29:31 * DTC Client socket (15) | Socket gracefully closed by remote side. | 2017-10-31 08:29:31 DTC Client socket (15) | Closed. | 2017-10-31 08:29:31 Rithmic Trading | Port for executable: 58372 | 2017-10-31 08:29:32 Listening socket (904). Port 58372 | Closed. | 2017-10-31 08:29:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:32 Rithmic Trading | Bridge process is running. | 2017-10-31 08:29:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58372 | 2017-10-31 08:29:34 DTC Client socket (20) | Creating socket. | 2017-10-31 08:29:34 DTC Client socket (20) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:34 Rithmic Trading | Connected to server. | 2017-10-31 08:29:34 Rithmic Trading | Starting socket receive thread. | 2017-10-31 08:29:34 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 08:29:34 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 08:29:34 Rithmic Trading | Sending logon request message. | 2017-10-31 08:29:34 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 08:29:34 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 08:29:34 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 08:29:34 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 08:29:35 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 08:29:35 Rithmic Trading | Received logon response. | 2017-10-31 08:29:35 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 08:29:35 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 08:29:35 Rithmic Trading | Logon error received from server | 2017-10-31 08:29:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:35 DTC Client socket (20) | Initiating close of socket by core. | 2017-10-31 08:29:35 Rithmic Trading | Disconnected. | 2017-10-31 08:29:35 DTC Client socket (20) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:29:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:35 Rithmic Trading | Port for executable: 58383 | 2017-10-31 08:29:38 Listening socket (444). Port 58383 | Closed. | 2017-10-31 08:29:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:38 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58383 | 2017-10-31 08:29:40 DTC Client socket (21) | Creating socket. | 2017-10-31 08:29:40 DTC Client socket (21) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:40 DTC Client socket (21) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:41 * DTC Client socket (21) | Initiating close of socket by core. | 2017-10-31 08:29:41 DTC Client socket (21) | Closed. | 2017-10-31 08:29:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:41 Rithmic Trading | Disconnected. | 2017-10-31 08:29:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:41 Rithmic Trading | Port for executable: 58385 | 2017-10-31 08:29:43 Listening socket (780). Port 58385 | Closed. | 2017-10-31 08:29:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:43 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58385 | 2017-10-31 08:29:45 DTC Client socket (22) | Creating socket. | 2017-10-31 08:29:45 DTC Client socket (22) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:45 DTC Client socket (22) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:46 * DTC Client socket (22) | Initiating close of socket by core. | 2017-10-31 08:29:46 DTC Client socket (22) | Closed. | 2017-10-31 08:29:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:46 Rithmic Trading | Disconnected. | 2017-10-31 08:29:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:46 Rithmic Trading | Port for executable: 58388 | 2017-10-31 08:29:48 Listening socket (444). Port 58388 | Closed. | 2017-10-31 08:29:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:48 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58388 | 2017-10-31 08:29:50 DTC Client socket (23) | Creating socket. | 2017-10-31 08:29:50 DTC Client socket (23) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:50 DTC Client socket (23) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:51 * DTC Client socket (23) | Initiating close of socket by core. | 2017-10-31 08:29:51 DTC Client socket (23) | Closed. | 2017-10-31 08:29:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:51 Rithmic Trading | Disconnected. | 2017-10-31 08:29:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:51 Rithmic Trading | Port for executable: 58391 | 2017-10-31 08:29:53 Listening socket (668). Port 58391 | Closed. | 2017-10-31 08:29:53 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:29:53 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:29:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58391 | 2017-10-31 08:29:55 DTC Client socket (24) | Creating socket. | 2017-10-31 08:29:55 DTC Client socket (24) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:29:55 DTC Client socket (24) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:29:56 * DTC Client socket (24) | Initiating close of socket by core. | 2017-10-31 08:29:56 DTC Client socket (24) | Closed. | 2017-10-31 08:29:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:29:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:56 Rithmic Trading | Disconnected. | 2017-10-31 08:29:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:29:56 File >> Disconnect selected. | 2017-10-31 08:29:56 Rithmic Trading | Disconnected. | 2017-10-31 08:29:56 DTC Client socket (20) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 08:29:57 * DTC Client socket (20) | Socket gracefully closed by remote side. | 2017-10-31 08:29:57 DTC Client socket (20) | Closed. | 2017-10-31 08:29:57 The above has been sent to support. | 2017-10-31 08:32:49 * HTTP connection to www.sierrachart.com:80 (26) | Creating socket. | 2017-10-31 08:32:49 HTTP connection to www.sierrachart.com:80 (26) | Connecting to IP: 204.15.192.108. | 2017-10-31 08:32:49 Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2017-10-31 08:32:50 HTTP connection to www.sierrachart.com:80 (26) | Socket gracefully closed by remote side. | 2017-10-31 08:32:55 HTTP connection to www.sierrachart.com:80 (26) | Initiating close of socket by core. | 2017-10-31 08:32:55 HTTP connection to www.sierrachart.com:80 (26) | Received socket Close event. | 2017-10-31 08:32:55 HTTP connection to www.sierrachart.com:80 (26) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-31 08:32:55 HTTP connection to www.sierrachart.com:80 (26) | Closed. | 2017-10-31 08:32:55 Rithmic Trading | Port for executable: 60184 | 2017-10-31 08:48:21 Listening socket (748). Port 60184 | Closed. | 2017-10-31 08:48:21 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:48:21 Rithmic Trading | Bridge process is running. | 2017-10-31 08:48:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60184 | 2017-10-31 08:48:23 DTC Client socket (32) | Creating socket. | 2017-10-31 08:48:23 DTC Client socket (32) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:48:23 Rithmic Trading | Connected to server. | 2017-10-31 08:48:23 Rithmic Trading | Starting socket receive thread. | 2017-10-31 08:48:23 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 08:48:23 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 08:48:23 Rithmic Trading | Sending logon request message. | 2017-10-31 08:48:23 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 08:48:23 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 08:48:23 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 08:48:23 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 08:48:25 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 08:48:25 Rithmic Trading | Received logon response. | 2017-10-31 08:48:25 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 08:48:25 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 08:48:25 Rithmic Trading | Logon error received from server | 2017-10-31 08:48:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:48:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:25 DTC Client socket (32) | Initiating close of socket by core. | 2017-10-31 08:48:25 DTC Client socket (32) | Shutdown started. Waiting for graceful close. | 2017-10-31 08:48:25 Rithmic Trading | Disconnected. | 2017-10-31 08:48:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:25 Rithmic Trading | Port for executable: 60194 | 2017-10-31 08:48:27 Listening socket (1000). Port 60194 | Closed. | 2017-10-31 08:48:27 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:48:27 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:48:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60194 | 2017-10-31 08:48:29 DTC Client socket (33) | Creating socket. | 2017-10-31 08:48:29 DTC Client socket (33) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:48:29 DTC Client socket (33) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:48:30 * DTC Client socket (33) | Initiating close of socket by core. | 2017-10-31 08:48:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:48:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:30 DTC Client socket (33) | Closed. | 2017-10-31 08:48:30 Rithmic Trading | Disconnected. | 2017-10-31 08:48:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:30 Rithmic Trading | Port for executable: 60196 | 2017-10-31 08:48:32 Listening socket (780). Port 60196 | Closed. | 2017-10-31 08:48:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:48:32 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:48:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60196 | 2017-10-31 08:48:34 DTC Client socket (34) | Creating socket. | 2017-10-31 08:48:34 DTC Client socket (34) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:48:34 DTC Client socket (34) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:48:35 * DTC Client socket (34) | Initiating close of socket by core. | 2017-10-31 08:48:35 DTC Client socket (34) | Closed. | 2017-10-31 08:48:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:48:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:35 Rithmic Trading | Disconnected. | 2017-10-31 08:48:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:35 Rithmic Trading | Port for executable: 60198 | 2017-10-31 08:48:37 Listening socket (1000). Port 60198 | Closed. | 2017-10-31 08:48:37 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:48:37 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:48:39 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60198 | 2017-10-31 08:48:39 DTC Client socket (35) | Creating socket. | 2017-10-31 08:48:39 DTC Client socket (35) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:48:39 DTC Client socket (35) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:48:41 * DTC Client socket (35) | Initiating close of socket by core. | 2017-10-31 08:48:41 DTC Client socket (35) | Closed. | 2017-10-31 08:48:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:48:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:41 Rithmic Trading | Disconnected. | 2017-10-31 08:48:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:41 Rithmic Trading | Port for executable: 60200 | 2017-10-31 08:48:43 Listening socket (780). Port 60200 | Closed. | 2017-10-31 08:48:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:48:43 Rithmic Trading | Bridge process is not running! | 2017-10-31 08:48:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60200 | 2017-10-31 08:48:45 DTC Client socket (36) | Creating socket. | 2017-10-31 08:48:45 DTC Client socket (36) | Connecting to IP: 127.0.0.1. | 2017-10-31 08:48:45 DTC Client socket (36) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 08:48:46 * DTC Client socket (36) | Initiating close of socket by core. | 2017-10-31 08:48:46 DTC Client socket (36) | Closed. | 2017-10-31 08:48:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 08:48:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:46 Rithmic Trading | Disconnected. | 2017-10-31 08:48:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 08:48:46 DTC Client socket (32) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 08:48:46 * DTC Client socket (32) | Socket gracefully closed by remote side. | 2017-10-31 08:48:46 DTC Client socket (32) | Closed. | 2017-10-31 08:48:46 Rithmic Trading | Port for executable: 60202 | 2017-10-31 08:48:48 Listening socket (972). Port 60202 | Closed. | 2017-10-31 08:48:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 08:48:48 File >> Disconnect selected. | 2017-10-31 08:48:48 Rithmic Trading | Disconnected. | 2017-10-31 08:48:48 Rithmic Trading | Port for executable: 59764 | 2017-10-31 09:09:33 Listening socket (780). Port 59764 | Closed. | 2017-10-31 09:09:33 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 09:09:33 Rithmic Trading | Bridge process is running. | 2017-10-31 09:09:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59764 | 2017-10-31 09:09:35 DTC Client socket (44) | Creating socket. | 2017-10-31 09:09:35 DTC Client socket (44) | Connecting to IP: 127.0.0.1. | 2017-10-31 09:09:35 Rithmic Trading | Connected to server. | 2017-10-31 09:09:35 Rithmic Trading | Starting socket receive thread. | 2017-10-31 09:09:35 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 09:09:35 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 09:09:35 Rithmic Trading | Sending logon request message. | 2017-10-31 09:09:35 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 09:09:35 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 09:09:35 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 09:09:35 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 09:09:37 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 09:09:37 Rithmic Trading | Received logon response. | 2017-10-31 09:09:37 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 09:09:37 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 09:09:37 Rithmic Trading | Logon error received from server | 2017-10-31 09:09:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 09:09:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:37 DTC Client socket (44) | Initiating close of socket by core. | 2017-10-31 09:09:38 DTC Client socket (44) | Shutdown started. Waiting for graceful close. | 2017-10-31 09:09:38 Rithmic Trading | Disconnected. | 2017-10-31 09:09:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:38 Rithmic Trading | Port for executable: 59774 | 2017-10-31 09:09:39 Listening socket (1000). Port 59774 | Closed. | 2017-10-31 09:09:39 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 09:09:39 Rithmic Trading | Bridge process is not running! | 2017-10-31 09:09:41 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59774 | 2017-10-31 09:09:41 DTC Client socket (45) | Creating socket. | 2017-10-31 09:09:41 DTC Client socket (45) | Connecting to IP: 127.0.0.1. | 2017-10-31 09:09:41 DTC Client socket (45) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 09:09:42 * DTC Client socket (45) | Initiating close of socket by core. | 2017-10-31 09:09:42 DTC Client socket (45) | Closed. | 2017-10-31 09:09:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 09:09:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:42 Rithmic Trading | Disconnected. | 2017-10-31 09:09:42 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:42 Rithmic Trading | Port for executable: 59776 | 2017-10-31 09:09:44 Listening socket (1080). Port 59776 | Closed. | 2017-10-31 09:09:44 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 09:09:44 Rithmic Trading | Bridge process is not running! | 2017-10-31 09:09:46 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59776 | 2017-10-31 09:09:46 DTC Client socket (46) | Creating socket. | 2017-10-31 09:09:46 DTC Client socket (46) | Connecting to IP: 127.0.0.1. | 2017-10-31 09:09:46 DTC Client socket (46) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 09:09:47 * DTC Client socket (46) | Initiating close of socket by core. | 2017-10-31 09:09:47 DTC Client socket (46) | Closed. | 2017-10-31 09:09:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 09:09:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:47 Rithmic Trading | Disconnected. | 2017-10-31 09:09:47 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:47 Rithmic Trading | Port for executable: 59778 | 2017-10-31 09:09:49 Listening socket (1000). Port 59778 | Closed. | 2017-10-31 09:09:49 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 09:09:49 Rithmic Trading | Bridge process is not running! | 2017-10-31 09:09:51 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59778 | 2017-10-31 09:09:51 DTC Client socket (47) | Creating socket. | 2017-10-31 09:09:51 DTC Client socket (47) | Connecting to IP: 127.0.0.1. | 2017-10-31 09:09:51 DTC Client socket (47) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 09:09:52 * DTC Client socket (47) | Initiating close of socket by core. | 2017-10-31 09:09:52 DTC Client socket (47) | Closed. | 2017-10-31 09:09:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 09:09:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:52 Rithmic Trading | Disconnected. | 2017-10-31 09:09:52 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:52 Rithmic Trading | Port for executable: 59780 | 2017-10-31 09:09:54 Listening socket (1080). Port 59780 | Closed. | 2017-10-31 09:09:54 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 09:09:54 Rithmic Trading | Bridge process is not running! | 2017-10-31 09:09:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59780 | 2017-10-31 09:09:56 DTC Client socket (48) | Creating socket. | 2017-10-31 09:09:56 DTC Client socket (48) | Connecting to IP: 127.0.0.1. | 2017-10-31 09:09:56 DTC Client socket (48) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 09:09:57 * DTC Client socket (48) | Initiating close of socket by core. | 2017-10-31 09:09:57 DTC Client socket (48) | Closed. | 2017-10-31 09:09:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 09:09:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:57 Rithmic Trading | Disconnected. | 2017-10-31 09:09:57 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 09:09:57 DTC Client socket (44) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 09:09:58 * DTC Client socket (44) | Socket gracefully closed by remote side. | 2017-10-31 09:09:58 DTC Client socket (44) | Closed. | 2017-10-31 09:09:58 Rithmic Trading | Port for executable: 59783 | 2017-10-31 09:09:59 Listening socket (780). Port 59783 | Closed. | 2017-10-31 09:09:59 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 09:09:59 File >> Disconnect selected. | 2017-10-31 09:09:59 Rithmic Trading | Disconnected. | 2017-10-31 09:09:59 Rithmic Trading | Port for executable: 55347 | 2017-10-31 10:38:08 Listening socket (1000). Port 55347 | Closed. | 2017-10-31 10:38:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:08 Rithmic Trading | Bridge process is running. | 2017-10-31 10:38:10 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55347 | 2017-10-31 10:38:10 DTC Client socket (80) | Creating socket. | 2017-10-31 10:38:10 DTC Client socket (80) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:10 Rithmic Trading | Connected to server. | 2017-10-31 10:38:10 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:38:10 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:38:10 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:38:10 Rithmic Trading | Sending logon request message. | 2017-10-31 10:38:10 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:38:10 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:38:10 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:38:10 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:38:12 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:38:12 Rithmic Trading | Received logon response. | 2017-10-31 10:38:12 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:38:12 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:38:12 Rithmic Trading | Logon error received from server | 2017-10-31 10:38:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:12 DTC Client socket (80) | Initiating close of socket by core. | 2017-10-31 10:38:12 Rithmic Trading | Disconnected. | 2017-10-31 10:38:12 DTC Client socket (80) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:38:12 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:12 Rithmic Trading | Port for executable: 55358 | 2017-10-31 10:38:14 Listening socket (904). Port 55358 | Closed. | 2017-10-31 10:38:14 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:14 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55358 | 2017-10-31 10:38:16 DTC Client socket (81) | Creating socket. | 2017-10-31 10:38:16 DTC Client socket (81) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:16 DTC Client socket (81) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:17 * DTC Client socket (81) | Initiating close of socket by core. | 2017-10-31 10:38:17 DTC Client socket (81) | Closed. | 2017-10-31 10:38:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:17 Rithmic Trading | Disconnected. | 2017-10-31 10:38:17 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:17 Rithmic Trading | Port for executable: 55362 | 2017-10-31 10:38:19 Listening socket (1084). Port 55362 | Closed. | 2017-10-31 10:38:19 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:19 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:21 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55362 | 2017-10-31 10:38:21 DTC Client socket (82) | Creating socket. | 2017-10-31 10:38:21 DTC Client socket (82) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:21 DTC Client socket (82) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:22 * DTC Client socket (82) | Initiating close of socket by core. | 2017-10-31 10:38:22 DTC Client socket (82) | Closed. | 2017-10-31 10:38:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:22 Rithmic Trading | Disconnected. | 2017-10-31 10:38:22 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:22 Rithmic Trading | Port for executable: 55365 | 2017-10-31 10:38:24 Listening socket (904). Port 55365 | Closed. | 2017-10-31 10:38:24 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:24 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55365 | 2017-10-31 10:38:26 DTC Client socket (83) | Creating socket. | 2017-10-31 10:38:26 DTC Client socket (83) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:26 DTC Client socket (83) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:27 * DTC Client socket (83) | Initiating close of socket by core. | 2017-10-31 10:38:27 DTC Client socket (83) | Closed. | 2017-10-31 10:38:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:27 Rithmic Trading | Disconnected. | 2017-10-31 10:38:27 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:27 Rithmic Trading | Port for executable: 55370 | 2017-10-31 10:38:29 Listening socket (1084). Port 55370 | Closed. | 2017-10-31 10:38:29 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:29 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55370 | 2017-10-31 10:38:31 DTC Client socket (84) | Creating socket. | 2017-10-31 10:38:31 DTC Client socket (84) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:31 DTC Client socket (84) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:32 * DTC Client socket (84) | Initiating close of socket by core. | 2017-10-31 10:38:32 DTC Client socket (84) | Closed. | 2017-10-31 10:38:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:32 Rithmic Trading | Disconnected. | 2017-10-31 10:38:32 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:32 DTC Client socket (80) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 10:38:33 * DTC Client socket (80) | Socket gracefully closed by remote side. | 2017-10-31 10:38:33 DTC Client socket (80) | Closed. | 2017-10-31 10:38:33 Rithmic Trading | Port for executable: 55374 | 2017-10-31 10:38:34 Listening socket (1000). Port 55374 | Closed. | 2017-10-31 10:38:34 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:34 Rithmic Trading | Bridge process is running. | 2017-10-31 10:38:36 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55374 | 2017-10-31 10:38:36 DTC Client socket (85) | Creating socket. | 2017-10-31 10:38:36 DTC Client socket (85) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:36 Rithmic Trading | Connected to server. | 2017-10-31 10:38:36 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:38:36 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:38:36 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:38:36 Rithmic Trading | Sending logon request message. | 2017-10-31 10:38:36 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:38:36 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:38:36 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:38:36 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:38:37 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:38:38 Rithmic Trading | Received logon response. | 2017-10-31 10:38:38 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:38:38 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:38:38 Rithmic Trading | Logon error received from server | 2017-10-31 10:38:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:38 DTC Client socket (85) | Initiating close of socket by core. | 2017-10-31 10:38:38 DTC Client socket (85) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:38:38 Rithmic Trading | Disconnected. | 2017-10-31 10:38:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:38 Rithmic Trading | Port for executable: 55386 | 2017-10-31 10:38:40 Listening socket (880). Port 55386 | Closed. | 2017-10-31 10:38:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:40 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:42 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55386 | 2017-10-31 10:38:42 DTC Client socket (86) | Creating socket. | 2017-10-31 10:38:42 DTC Client socket (86) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:42 DTC Client socket (86) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:43 * DTC Client socket (86) | Initiating close of socket by core. | 2017-10-31 10:38:43 DTC Client socket (86) | Closed. | 2017-10-31 10:38:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:43 Rithmic Trading | Disconnected. | 2017-10-31 10:38:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:43 Rithmic Trading | Port for executable: 55388 | 2017-10-31 10:38:45 Listening socket (1084). Port 55388 | Closed. | 2017-10-31 10:38:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:45 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:47 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55388 | 2017-10-31 10:38:47 DTC Client socket (87) | Creating socket. | 2017-10-31 10:38:47 DTC Client socket (87) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:47 DTC Client socket (87) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:48 * DTC Client socket (87) | Initiating close of socket by core. | 2017-10-31 10:38:48 DTC Client socket (87) | Closed. | 2017-10-31 10:38:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:48 Rithmic Trading | Disconnected. | 2017-10-31 10:38:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:48 Rithmic Trading | Port for executable: 55392 | 2017-10-31 10:38:50 Listening socket (880). Port 55392 | Closed. | 2017-10-31 10:38:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:50 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:52 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55392 | 2017-10-31 10:38:52 DTC Client socket (88) | Creating socket. | 2017-10-31 10:38:52 DTC Client socket (88) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:52 DTC Client socket (88) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:53 * DTC Client socket (88) | Initiating close of socket by core. | 2017-10-31 10:38:53 DTC Client socket (88) | Closed. | 2017-10-31 10:38:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:53 Rithmic Trading | Disconnected. | 2017-10-31 10:38:53 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:53 Rithmic Trading | Port for executable: 55394 | 2017-10-31 10:38:55 Listening socket (1084). Port 55394 | Closed. | 2017-10-31 10:38:55 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:38:55 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:38:57 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55394 | 2017-10-31 10:38:57 DTC Client socket (89) | Creating socket. | 2017-10-31 10:38:57 DTC Client socket (89) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:38:57 DTC Client socket (89) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:38:58 * DTC Client socket (89) | Initiating close of socket by core. | 2017-10-31 10:38:58 DTC Client socket (89) | Closed. | 2017-10-31 10:38:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:38:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:58 Rithmic Trading | Disconnected. | 2017-10-31 10:38:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:38:58 DTC Client socket (85) | Socket gracefully closed by remote side. | 2017-10-31 10:38:59 DTC Client socket (85) | Closed. | 2017-10-31 10:38:59 Rithmic Trading | Port for executable: 55398 | 2017-10-31 10:39:00 Listening socket (1000). Port 55398 | Closed. | 2017-10-31 10:39:00 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:00 Rithmic Trading | Bridge process is running. | 2017-10-31 10:39:02 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55398 | 2017-10-31 10:39:02 DTC Client socket (90) | Creating socket. | 2017-10-31 10:39:02 DTC Client socket (90) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:02 Rithmic Trading | Connected to server. | 2017-10-31 10:39:02 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:39:02 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:39:02 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:39:02 Rithmic Trading | Sending logon request message. | 2017-10-31 10:39:02 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:39:02 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:39:02 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:39:02 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:39:03 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:39:04 Rithmic Trading | Received logon response. | 2017-10-31 10:39:04 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:39:04 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:39:04 Rithmic Trading | Logon error received from server | 2017-10-31 10:39:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:04 DTC Client socket (90) | Initiating close of socket by core. | 2017-10-31 10:39:04 DTC Client socket (90) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:39:04 Rithmic Trading | Disconnected. | 2017-10-31 10:39:04 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:04 Rithmic Trading | Port for executable: 55408 | 2017-10-31 10:39:06 Listening socket (1084). Port 55408 | Closed. | 2017-10-31 10:39:06 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:06 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55408 | 2017-10-31 10:39:08 DTC Client socket (91) | Creating socket. | 2017-10-31 10:39:08 DTC Client socket (91) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:08 DTC Client socket (91) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:09 * DTC Client socket (91) | Initiating close of socket by core. | 2017-10-31 10:39:09 DTC Client socket (91) | Closed. | 2017-10-31 10:39:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:09 Rithmic Trading | Disconnected. | 2017-10-31 10:39:09 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:09 Rithmic Trading | Port for executable: 55413 | 2017-10-31 10:39:11 Listening socket (880). Port 55413 | Closed. | 2017-10-31 10:39:11 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:11 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55413 | 2017-10-31 10:39:13 DTC Client socket (92) | Creating socket. | 2017-10-31 10:39:13 DTC Client socket (92) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:13 DTC Client socket (92) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:14 * DTC Client socket (92) | Initiating close of socket by core. | 2017-10-31 10:39:14 DTC Client socket (92) | Closed. | 2017-10-31 10:39:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:14 Rithmic Trading | Disconnected. | 2017-10-31 10:39:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:14 Rithmic Trading | Port for executable: 55415 | 2017-10-31 10:39:16 Listening socket (1084). Port 55415 | Closed. | 2017-10-31 10:39:16 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:16 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55415 | 2017-10-31 10:39:18 DTC Client socket (93) | Creating socket. | 2017-10-31 10:39:18 DTC Client socket (93) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:18 DTC Client socket (93) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:19 * DTC Client socket (93) | Initiating close of socket by core. | 2017-10-31 10:39:19 DTC Client socket (93) | Closed. | 2017-10-31 10:39:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:19 Rithmic Trading | Disconnected. | 2017-10-31 10:39:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:19 Rithmic Trading | Port for executable: 55418 | 2017-10-31 10:39:21 Listening socket (880). Port 55418 | Closed. | 2017-10-31 10:39:21 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:21 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55418 | 2017-10-31 10:39:23 DTC Client socket (94) | Creating socket. | 2017-10-31 10:39:23 DTC Client socket (94) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:23 DTC Client socket (94) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:24 * DTC Client socket (94) | Initiating close of socket by core. | 2017-10-31 10:39:24 DTC Client socket (94) | Closed. | 2017-10-31 10:39:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:24 Rithmic Trading | Disconnected. | 2017-10-31 10:39:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:24 DTC Client socket (90) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 10:39:25 * DTC Client socket (90) | Socket gracefully closed by remote side. | 2017-10-31 10:39:25 DTC Client socket (90) | Closed. | 2017-10-31 10:39:25 Rithmic Trading | Port for executable: 55422 | 2017-10-31 10:39:26 Listening socket (668). Port 55422 | Closed. | 2017-10-31 10:39:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:26 Rithmic Trading | Bridge process is running. | 2017-10-31 10:39:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55422 | 2017-10-31 10:39:28 DTC Client socket (95) | Creating socket. | 2017-10-31 10:39:28 DTC Client socket (95) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:28 Rithmic Trading | Connected to server. | 2017-10-31 10:39:28 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:39:28 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:39:28 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:39:28 Rithmic Trading | Sending logon request message. | 2017-10-31 10:39:28 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:39:28 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:39:28 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:39:28 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:39:29 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:39:30 Rithmic Trading | Received logon response. | 2017-10-31 10:39:30 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:39:30 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:39:30 Rithmic Trading | Logon error received from server | 2017-10-31 10:39:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:30 DTC Client socket (95) | Initiating close of socket by core. | 2017-10-31 10:39:30 DTC Client socket (95) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:39:30 Rithmic Trading | Disconnected. | 2017-10-31 10:39:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:30 Rithmic Trading | Port for executable: 55433 | 2017-10-31 10:39:32 Listening socket (1084). Port 55433 | Closed. | 2017-10-31 10:39:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:32 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55433 | 2017-10-31 10:39:34 DTC Client socket (96) | Creating socket. | 2017-10-31 10:39:34 DTC Client socket (96) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:34 DTC Client socket (96) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:34 * DTC Client socket (96) | Initiating close of socket by core. | 2017-10-31 10:39:34 DTC Client socket (96) | Closed. | 2017-10-31 10:39:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:34 Rithmic Trading | Disconnected. | 2017-10-31 10:39:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:35 Rithmic Trading | Port for executable: 55435 | 2017-10-31 10:39:36 Listening socket (1080). Port 55435 | Closed. | 2017-10-31 10:39:36 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:36 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:38 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55435 | 2017-10-31 10:39:38 DTC Client socket (97) | Creating socket. | 2017-10-31 10:39:38 DTC Client socket (97) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:38 DTC Client socket (97) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:39 * DTC Client socket (97) | Initiating close of socket by core. | 2017-10-31 10:39:39 DTC Client socket (97) | Closed. | 2017-10-31 10:39:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:39 Rithmic Trading | Disconnected. | 2017-10-31 10:39:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:39 Rithmic Trading | Port for executable: 55438 | 2017-10-31 10:39:41 Listening socket (1084). Port 55438 | Closed. | 2017-10-31 10:39:41 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:41 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55438 | 2017-10-31 10:39:43 DTC Client socket (98) | Creating socket. | 2017-10-31 10:39:43 DTC Client socket (98) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:43 DTC Client socket (98) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:44 * DTC Client socket (98) | Initiating close of socket by core. | 2017-10-31 10:39:44 DTC Client socket (98) | Closed. | 2017-10-31 10:39:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:44 Rithmic Trading | Disconnected. | 2017-10-31 10:39:44 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:44 Rithmic Trading | Port for executable: 55440 | 2017-10-31 10:39:46 Listening socket (1080). Port 55440 | Closed. | 2017-10-31 10:39:46 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:46 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:39:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55440 | 2017-10-31 10:39:48 DTC Client socket (99) | Creating socket. | 2017-10-31 10:39:48 DTC Client socket (99) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:48 DTC Client socket (99) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:39:50 * DTC Client socket (99) | Initiating close of socket by core. | 2017-10-31 10:39:50 DTC Client socket (99) | Closed. | 2017-10-31 10:39:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:50 Rithmic Trading | Disconnected. | 2017-10-31 10:39:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:50 DTC Client socket (95) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 10:39:51 * DTC Client socket (95) | Socket gracefully closed by remote side. | 2017-10-31 10:39:51 DTC Client socket (95) | Closed. | 2017-10-31 10:39:51 Rithmic Trading | Port for executable: 55443 | 2017-10-31 10:39:52 Listening socket (880). Port 55443 | Closed. | 2017-10-31 10:39:52 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:52 Rithmic Trading | Bridge process is running. | 2017-10-31 10:39:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55443 | 2017-10-31 10:39:54 DTC Client socket (100) | Creating socket. | 2017-10-31 10:39:54 DTC Client socket (100) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:39:54 Rithmic Trading | Connected to server. | 2017-10-31 10:39:54 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:39:54 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:39:54 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:39:54 Rithmic Trading | Sending logon request message. | 2017-10-31 10:39:54 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:39:54 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:39:54 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:39:54 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:39:55 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:39:56 Rithmic Trading | Received logon response. | 2017-10-31 10:39:56 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:39:56 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:39:56 Rithmic Trading | Logon error received from server | 2017-10-31 10:39:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:39:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:56 DTC Client socket (100) | Initiating close of socket by core. | 2017-10-31 10:39:56 DTC Client socket (100) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:39:56 Rithmic Trading | Disconnected. | 2017-10-31 10:39:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:39:56 Rithmic Trading | Port for executable: 55454 | 2017-10-31 10:39:58 Listening socket (1080). Port 55454 | Closed. | 2017-10-31 10:39:58 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:39:58 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55454 | 2017-10-31 10:40:00 DTC Client socket (101) | Creating socket. | 2017-10-31 10:40:00 DTC Client socket (101) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:00 DTC Client socket (101) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:01 * DTC Client socket (101) | Initiating close of socket by core. | 2017-10-31 10:40:01 DTC Client socket (101) | Closed. | 2017-10-31 10:40:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:01 Rithmic Trading | Disconnected. | 2017-10-31 10:40:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:01 Rithmic Trading | Port for executable: 55457 | 2017-10-31 10:40:03 Listening socket (1084). Port 55457 | Closed. | 2017-10-31 10:40:03 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:03 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:05 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55457 | 2017-10-31 10:40:05 DTC Client socket (102) | Creating socket. | 2017-10-31 10:40:05 DTC Client socket (102) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:05 DTC Client socket (102) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:06 * DTC Client socket (102) | Initiating close of socket by core. | 2017-10-31 10:40:06 DTC Client socket (102) | Closed. | 2017-10-31 10:40:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:06 Rithmic Trading | Disconnected. | 2017-10-31 10:40:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:06 Rithmic Trading | Port for executable: 55460 | 2017-10-31 10:40:08 Listening socket (1080). Port 55460 | Closed. | 2017-10-31 10:40:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:08 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:10 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55460 | 2017-10-31 10:40:10 DTC Client socket (103) | Creating socket. | 2017-10-31 10:40:10 DTC Client socket (103) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:10 DTC Client socket (103) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:10 * DTC Client socket (103) | Initiating close of socket by core. | 2017-10-31 10:40:10 DTC Client socket (103) | Closed. | 2017-10-31 10:40:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:10 Rithmic Trading | Disconnected. | 2017-10-31 10:40:11 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:11 Rithmic Trading | Port for executable: 55463 | 2017-10-31 10:40:12 Listening socket (1084). Port 55463 | Closed. | 2017-10-31 10:40:12 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:12 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:14 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55463 | 2017-10-31 10:40:14 DTC Client socket (104) | Creating socket. | 2017-10-31 10:40:14 DTC Client socket (104) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:14 DTC Client socket (104) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:15 * DTC Client socket (104) | Initiating close of socket by core. | 2017-10-31 10:40:15 DTC Client socket (104) | Closed. | 2017-10-31 10:40:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:15 Rithmic Trading | Disconnected. | 2017-10-31 10:40:15 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:15 DTC Client socket (100) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 10:40:17 * DTC Client socket (100) | Socket gracefully closed by remote side. | 2017-10-31 10:40:17 DTC Client socket (100) | Closed. | 2017-10-31 10:40:17 Rithmic Trading | Port for executable: 55466 | 2017-10-31 10:40:17 Listening socket (880). Port 55466 | Closed. | 2017-10-31 10:40:17 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:17 Rithmic Trading | Bridge process is running. | 2017-10-31 10:40:19 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55466 | 2017-10-31 10:40:19 DTC Client socket (105) | Creating socket. | 2017-10-31 10:40:19 DTC Client socket (105) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:19 Rithmic Trading | Connected to server. | 2017-10-31 10:40:19 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:40:19 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:40:19 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:40:19 Rithmic Trading | Sending logon request message. | 2017-10-31 10:40:19 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:40:19 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:40:19 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:40:19 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:40:21 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:40:21 Rithmic Trading | Received logon response. | 2017-10-31 10:40:21 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:40:21 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:40:21 Rithmic Trading | Logon error received from server | 2017-10-31 10:40:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:21 DTC Client socket (105) | Initiating close of socket by core. | 2017-10-31 10:40:21 DTC Client socket (105) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:40:21 Rithmic Trading | Disconnected. | 2017-10-31 10:40:21 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:21 Rithmic Trading | Port for executable: 55476 | 2017-10-31 10:40:23 Listening socket (668). Port 55476 | Closed. | 2017-10-31 10:40:23 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:23 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55476 | 2017-10-31 10:40:26 DTC Client socket (106) | Creating socket. | 2017-10-31 10:40:26 DTC Client socket (106) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:26 DTC Client socket (106) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:27 * DTC Client socket (106) | Initiating close of socket by core. | 2017-10-31 10:40:27 DTC Client socket (106) | Closed. | 2017-10-31 10:40:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:27 Rithmic Trading | Disconnected. | 2017-10-31 10:40:27 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:27 Rithmic Trading | Port for executable: 55481 | 2017-10-31 10:40:29 Listening socket (1084). Port 55481 | Closed. | 2017-10-31 10:40:29 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:29 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55481 | 2017-10-31 10:40:31 DTC Client socket (108) | Creating socket. | 2017-10-31 10:40:31 DTC Client socket (108) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:31 DTC Client socket (108) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:32 * DTC Client socket (108) | Initiating close of socket by core. | 2017-10-31 10:40:32 DTC Client socket (108) | Closed. | 2017-10-31 10:40:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:32 Rithmic Trading | Disconnected. | 2017-10-31 10:40:32 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:32 Rithmic Trading | Port for executable: 55491 | 2017-10-31 10:40:34 Listening socket (668). Port 55491 | Closed. | 2017-10-31 10:40:34 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:34 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:36 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55491 | 2017-10-31 10:40:36 DTC Client socket (109) | Creating socket. | 2017-10-31 10:40:36 DTC Client socket (109) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:36 DTC Client socket (109) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:36 * DTC Client socket (109) | Initiating close of socket by core. | 2017-10-31 10:40:36 DTC Client socket (109) | Closed. | 2017-10-31 10:40:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:36 Rithmic Trading | Disconnected. | 2017-10-31 10:40:37 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:37 Rithmic Trading | Port for executable: 54567 | 2017-10-31 10:40:38 Listening socket (1084). Port 54567 | Closed. | 2017-10-31 10:40:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:38 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54567 | 2017-10-31 10:40:40 DTC Client socket (110) | Creating socket. | 2017-10-31 10:40:40 DTC Client socket (110) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:40 DTC Client socket (110) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:41 * DTC Client socket (110) | Initiating close of socket by core. | 2017-10-31 10:40:41 DTC Client socket (110) | Closed. | 2017-10-31 10:40:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:41 Rithmic Trading | Disconnected. | 2017-10-31 10:40:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:41 DTC Client socket (105) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 10:40:43 * DTC Client socket (105) | Socket gracefully closed by remote side. | 2017-10-31 10:40:43 DTC Client socket (105) | Closed. | 2017-10-31 10:40:43 Rithmic Trading | Port for executable: 56549 | 2017-10-31 10:40:43 Listening socket (880). Port 56549 | Closed. | 2017-10-31 10:40:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:43 Rithmic Trading | Bridge process is running. | 2017-10-31 10:40:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56549 | 2017-10-31 10:40:45 DTC Client socket (111) | Creating socket. | 2017-10-31 10:40:45 DTC Client socket (111) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:45 Rithmic Trading | Connected to server. | 2017-10-31 10:40:45 Rithmic Trading | Starting socket receive thread. | 2017-10-31 10:40:45 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 10:40:45 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 10:40:45 Rithmic Trading | Sending logon request message. | 2017-10-31 10:40:45 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 10:40:45 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 10:40:45 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 10:40:45 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 10:40:47 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 10:40:47 Rithmic Trading | Received logon response. | 2017-10-31 10:40:47 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 10:40:47 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 10:40:47 Rithmic Trading | Logon error received from server | 2017-10-31 10:40:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:47 DTC Client socket (111) | Initiating close of socket by core. | 2017-10-31 10:40:47 DTC Client socket (111) | Shutdown started. Waiting for graceful close. | 2017-10-31 10:40:47 Rithmic Trading | Disconnected. | 2017-10-31 10:40:47 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:47 Rithmic Trading | Port for executable: 56559 | 2017-10-31 10:40:49 Listening socket (748). Port 56559 | Closed. | 2017-10-31 10:40:49 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:49 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:51 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56559 | 2017-10-31 10:40:51 DTC Client socket (112) | Creating socket. | 2017-10-31 10:40:51 DTC Client socket (112) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:51 DTC Client socket (112) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:52 * DTC Client socket (112) | Initiating close of socket by core. | 2017-10-31 10:40:52 DTC Client socket (112) | Closed. | 2017-10-31 10:40:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:52 Rithmic Trading | Disconnected. | 2017-10-31 10:40:52 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:52 Rithmic Trading | Port for executable: 56561 | 2017-10-31 10:40:54 Listening socket (1084). Port 56561 | Closed. | 2017-10-31 10:40:54 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:40:54 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:40:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56561 | 2017-10-31 10:40:56 DTC Client socket (113) | Creating socket. | 2017-10-31 10:40:56 DTC Client socket (113) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:40:56 DTC Client socket (113) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:40:57 * DTC Client socket (113) | Initiating close of socket by core. | 2017-10-31 10:40:57 DTC Client socket (113) | Closed. | 2017-10-31 10:40:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:40:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:57 Rithmic Trading | Disconnected. | 2017-10-31 10:40:57 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:40:57 Rithmic Trading | Port for executable: 56564 | 2017-10-31 10:41:00 Listening socket (748). Port 56564 | Closed. | 2017-10-31 10:41:00 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:41:00 Rithmic Trading | Bridge process is not running! | 2017-10-31 10:41:02 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56564 | 2017-10-31 10:41:02 DTC Client socket (114) | Creating socket. | 2017-10-31 10:41:02 DTC Client socket (114) | Connecting to IP: 127.0.0.1. | 2017-10-31 10:41:02 DTC Client socket (114) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 10:41:03 * DTC Client socket (114) | Initiating close of socket by core. | 2017-10-31 10:41:03 DTC Client socket (114) | Closed. | 2017-10-31 10:41:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 10:41:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:41:03 Rithmic Trading | Disconnected. | 2017-10-31 10:41:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 10:41:03 Rithmic Trading | Port for executable: 56566 | 2017-10-31 10:41:05 Listening socket (1084). Port 56566 | Closed. | 2017-10-31 10:41:05 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 10:41:05 File >> Disconnect selected. | 2017-10-31 10:41:06 Rithmic Trading | Disconnected. | 2017-10-31 10:41:06 DTC Client socket (111) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 10:41:09 * DTC Client socket (111) | Socket gracefully closed by remote side. | 2017-10-31 10:41:09 DTC Client socket (111) | Closed. | 2017-10-31 10:41:09 Rithmic Trading | Port for executable: 63647 | 2017-10-31 12:05:01 Listening socket (880). Port 63647 | Closed. | 2017-10-31 12:05:01 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:01 Rithmic Trading | Bridge process is running. | 2017-10-31 12:05:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63647 | 2017-10-31 12:05:04 DTC Client socket (144) | Creating socket. | 2017-10-31 12:05:04 DTC Client socket (144) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:04 Rithmic Trading | Connected to server. | 2017-10-31 12:05:04 Rithmic Trading | Starting socket receive thread. | 2017-10-31 12:05:04 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 12:05:04 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 12:05:04 Rithmic Trading | Sending logon request message. | 2017-10-31 12:05:04 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 12:05:04 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 12:05:04 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 12:05:04 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 12:05:05 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 12:05:06 Rithmic Trading | Received logon response. | 2017-10-31 12:05:06 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 12:05:06 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 12:05:06 Rithmic Trading | Logon error received from server | 2017-10-31 12:05:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:06 DTC Client socket (144) | Initiating close of socket by core. | 2017-10-31 12:05:06 Rithmic Trading | Disconnected. | 2017-10-31 12:05:06 DTC Client socket (144) | Shutdown started. Waiting for graceful close. | 2017-10-31 12:05:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:06 Rithmic Trading | Port for executable: 63658 | 2017-10-31 12:05:08 Listening socket (1056). Port 63658 | Closed. | 2017-10-31 12:05:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:08 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:10 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63658 | 2017-10-31 12:05:10 DTC Client socket (145) | Creating socket. | 2017-10-31 12:05:10 DTC Client socket (145) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:10 DTC Client socket (145) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:11 * DTC Client socket (145) | Initiating close of socket by core. | 2017-10-31 12:05:11 DTC Client socket (145) | Closed. | 2017-10-31 12:05:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:11 Rithmic Trading | Disconnected. | 2017-10-31 12:05:11 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:11 Rithmic Trading | Port for executable: 63660 | 2017-10-31 12:05:13 Listening socket (1080). Port 63660 | Closed. | 2017-10-31 12:05:13 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:13 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:15 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63660 | 2017-10-31 12:05:15 DTC Client socket (146) | Creating socket. | 2017-10-31 12:05:15 DTC Client socket (146) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:15 DTC Client socket (146) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:16 * DTC Client socket (146) | Initiating close of socket by core. | 2017-10-31 12:05:16 DTC Client socket (146) | Closed. | 2017-10-31 12:05:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:16 Rithmic Trading | Disconnected. | 2017-10-31 12:05:16 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:16 Rithmic Trading | Port for executable: 63662 | 2017-10-31 12:05:18 Listening socket (1056). Port 63662 | Closed. | 2017-10-31 12:05:18 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:18 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63662 | 2017-10-31 12:05:20 DTC Client socket (147) | Creating socket. | 2017-10-31 12:05:20 DTC Client socket (147) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:20 DTC Client socket (147) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:21 * DTC Client socket (147) | Initiating close of socket by core. | 2017-10-31 12:05:21 DTC Client socket (147) | Closed. | 2017-10-31 12:05:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:21 Rithmic Trading | Disconnected. | 2017-10-31 12:05:21 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:21 Rithmic Trading | Port for executable: 63664 | 2017-10-31 12:05:23 Listening socket (1080). Port 63664 | Closed. | 2017-10-31 12:05:23 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:23 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:24 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63664 | 2017-10-31 12:05:24 DTC Client socket (148) | Creating socket. | 2017-10-31 12:05:24 DTC Client socket (148) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:24 DTC Client socket (148) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:25 * DTC Client socket (148) | Initiating close of socket by core. | 2017-10-31 12:05:25 DTC Client socket (148) | Closed. | 2017-10-31 12:05:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:25 Rithmic Trading | Disconnected. | 2017-10-31 12:05:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:25 DTC Client socket (144) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 12:05:27 * DTC Client socket (144) | Socket gracefully closed by remote side. | 2017-10-31 12:05:27 DTC Client socket (144) | Closed. | 2017-10-31 12:05:27 Rithmic Trading | Port for executable: 63667 | 2017-10-31 12:05:27 Listening socket (668). Port 63667 | Closed. | 2017-10-31 12:05:27 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:27 Rithmic Trading | Bridge process is running. | 2017-10-31 12:05:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63667 | 2017-10-31 12:05:29 DTC Client socket (149) | Creating socket. | 2017-10-31 12:05:29 DTC Client socket (149) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:29 Rithmic Trading | Connected to server. | 2017-10-31 12:05:29 Rithmic Trading | Starting socket receive thread. | 2017-10-31 12:05:29 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 12:05:29 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 12:05:29 Rithmic Trading | Sending logon request message. | 2017-10-31 12:05:29 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 12:05:29 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 12:05:29 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 12:05:29 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 12:05:31 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 12:05:31 Rithmic Trading | Received logon response. | 2017-10-31 12:05:31 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 12:05:31 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 12:05:31 Rithmic Trading | Logon error received from server | 2017-10-31 12:05:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:31 DTC Client socket (149) | Initiating close of socket by core. | 2017-10-31 12:05:31 DTC Client socket (149) | Shutdown started. Waiting for graceful close. | 2017-10-31 12:05:31 Rithmic Trading | Disconnected. | 2017-10-31 12:05:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:31 Rithmic Trading | Port for executable: 63677 | 2017-10-31 12:05:33 Listening socket (444). Port 63677 | Closed. | 2017-10-31 12:05:33 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:33 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63677 | 2017-10-31 12:05:35 DTC Client socket (150) | Creating socket. | 2017-10-31 12:05:35 DTC Client socket (150) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:35 DTC Client socket (150) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:36 * DTC Client socket (150) | Initiating close of socket by core. | 2017-10-31 12:05:36 DTC Client socket (150) | Closed. | 2017-10-31 12:05:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:36 Rithmic Trading | Disconnected. | 2017-10-31 12:05:36 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:36 Rithmic Trading | Port for executable: 63679 | 2017-10-31 12:05:38 Listening socket (904). Port 63679 | Closed. | 2017-10-31 12:05:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:38 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63679 | 2017-10-31 12:05:40 DTC Client socket (151) | Creating socket. | 2017-10-31 12:05:40 DTC Client socket (151) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:40 DTC Client socket (151) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:41 * DTC Client socket (151) | Initiating close of socket by core. | 2017-10-31 12:05:41 DTC Client socket (151) | Closed. | 2017-10-31 12:05:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:41 Rithmic Trading | Disconnected. | 2017-10-31 12:05:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:41 Rithmic Trading | Port for executable: 63681 | 2017-10-31 12:05:43 Listening socket (444). Port 63681 | Closed. | 2017-10-31 12:05:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:43 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63681 | 2017-10-31 12:05:45 DTC Client socket (152) | Creating socket. | 2017-10-31 12:05:45 DTC Client socket (152) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:45 DTC Client socket (152) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:46 * DTC Client socket (152) | Initiating close of socket by core. | 2017-10-31 12:05:46 DTC Client socket (152) | Closed. | 2017-10-31 12:05:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:46 Rithmic Trading | Disconnected. | 2017-10-31 12:05:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:46 Rithmic Trading | Port for executable: 63683 | 2017-10-31 12:05:48 Listening socket (904). Port 63683 | Closed. | 2017-10-31 12:05:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:48 Rithmic Trading | Bridge process is not running! | 2017-10-31 12:05:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63683 | 2017-10-31 12:05:50 DTC Client socket (153) | Creating socket. | 2017-10-31 12:05:50 DTC Client socket (153) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:50 DTC Client socket (153) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-10-31 12:05:51 * DTC Client socket (153) | Initiating close of socket by core. | 2017-10-31 12:05:51 DTC Client socket (153) | Closed. | 2017-10-31 12:05:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:51 Rithmic Trading | Disconnected. | 2017-10-31 12:05:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:51 DTC Client socket (149) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 12:05:53 * DTC Client socket (149) | Socket gracefully closed by remote side. | 2017-10-31 12:05:53 DTC Client socket (149) | Closed. | 2017-10-31 12:05:53 Rithmic Trading | Port for executable: 63685 | 2017-10-31 12:05:53 Listening socket (668). Port 63685 | Closed. | 2017-10-31 12:05:53 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:53 Rithmic Trading | Bridge process is running. | 2017-10-31 12:05:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63685 | 2017-10-31 12:05:55 DTC Client socket (154) | Creating socket. | 2017-10-31 12:05:55 DTC Client socket (154) | Connecting to IP: 127.0.0.1. | 2017-10-31 12:05:55 Rithmic Trading | Connected to server. | 2017-10-31 12:05:55 Rithmic Trading | Starting socket receive thread. | 2017-10-31 12:05:55 Rithmic Trading | Sending Encoding Request to server | 2017-10-31 12:05:55 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-31 12:05:55 Rithmic Trading | Sending logon request message. | 2017-10-31 12:05:55 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-31 12:05:55 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-31 12:05:55 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-10-31 12:05:55 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-31 12:05:57 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 12:05:57 Rithmic Trading | Received logon response. | 2017-10-31 12:05:57 Rithmic Trading | Server Name: DTC Bridge. | 2017-10-31 12:05:57 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-10-31 12:05:57 Rithmic Trading | Logon error received from server | 2017-10-31 12:05:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-31 12:05:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:57 DTC Client socket (154) | Initiating close of socket by core. | 2017-10-31 12:05:57 DTC Client socket (154) | Shutdown started. Waiting for graceful close. | 2017-10-31 12:05:57 Rithmic Trading | Disconnected. | 2017-10-31 12:05:57 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-31 12:05:57 Rithmic Trading | Port for executable: 63695 | 2017-10-31 12:05:59 Listening socket (880). Port 63695 | Closed. | 2017-10-31 12:05:59 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-31 12:05:59 File >> Disconnect selected. | 2017-10-31 12:06:00 Rithmic Trading | Disconnected. | 2017-10-31 12:06:00 DTC Client socket (154) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2017-10-31 12:06:19 * DTC Client socket (154) | Socket gracefully closed by remote side. | 2017-10-31 12:06:19 DTC Client socket (154) | Closed. | 2017-10-31 12:06:19 |
[2017-10-31 17:21:24] |
You are receiving a Permission Denied error from Rithmic: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-31 12:05:57 Refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
