Date/Time: Thu, 16 Jan 2025 11:05:39 +0000
Additional Renko Issue
View Count: 726
[2017-10-31 13:17:04]
User12041 - Posts: 25
there is an additional renko issue that I see. it is the starting position of the bricks at session starts. Take a look at the CLZ7 (rithmic data) open at 9:00 pm eastern standard time. You can see the bricks don't align with the overnight session bricks. I understand that at the open there may be gaps, etc. but the bricks of a new session should align with previous session bricks. this is important for those who use renko bars without wicks because when support and resistance is plotted across the chart it is important that the bricks line up across the chart. In the current format after many sessions the bricks can get really unaligned across many sessions of the chart. the issue of gaps and unaligned bricks during a single session has been resolved...so thank you for that. Not sure if there is a fix for this but I just wanted to let you know.
[2017-10-31 16:55:47]
Refer to this section here about this:
Renko Bar Charts: Opening Price for First Renko Bar and Alignment (Aligned Renko Bars)
In Chart >> Chart Settings what are the session times you are using?
[2017-10-31 18:49:32]
Fixed the issue. Was using standard renko and I just unchecked the box "New Bar At Session Start" and now all is good.
[2017-10-31 21:14:52]
OK good. So looks like everything is all set with the new Renko implementation.
