Date/Time: Thu, 16 Jan 2025 10:40:56 +0000
Upgrade from 3 to 5
View Count: 954
[2017-10-31 12:21:32] |
joshfutures - Posts: 3 |
I upgraded after the trial but just realized I need package 5 for footprint. Is there a way to upgrade and pay the difference?
[2017-10-31 16:57:11] |
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. Click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
