Date/Time: Fri, 17 Jan 2025 07:33:43 +0000
How To Get StorageBlock From Another Chart
View Count: 944
[2017-10-30 22:11:43] |
CustomIndicators - Posts: 126 |
Is it possible to get the StorageBlock from a study on another chart in ACSIL? I'm having trouble finding a way to do this.
[2017-10-31 09:04:24] |
Do you really need this capability? We can add this.
[2017-10-31 15:16:16] |
This feature would be very helpful to me, due to how I use storage blocks. I would appreciate if you could add it. :)
[2017-11-02 02:14:36] |
If you are planning to put this feature in, when may I expect it? I would like to add it to my studies. If its already in, what is the function called? Something like this?: sc.GetStudyStorageBlockFromChart(int ChartNumber, int StudyID); Asking for in case you don't document it right away. |
[2017-11-02 02:26:46] |
For the time being we do not know when we can do this.
[2017-12-10 09:47:31] |
We are working on adding this now.
