Date/Time: Thu, 16 Jan 2025 11:09:07 +0000
Continuous Scanning
View Count: 1191
[2017-10-30 21:21:42] |
User114693 - Posts: 3 |
I saw in another post that you guys could add an option for continuous scanning. Could I get that option please. Thank you. Reference Post number 53162 |
[2017-10-30 21:46:01] |
This is available in the latest release. The command is: Chart >> Enable Continuous Scanning.
[2017-10-31 03:40:27] |
4646ed - Posts: 230 |
Any way of regulating the time that the scanning takes-- slow it down so that each chart is visible for say 30 seconds or a minute, or even longer? This would be handy if you want to visually confirm the results. The way it is designed now it flips through charts with less than a second each perpetually looking for the alert condition. I'm thinking that a steady but slower flipping through would be useful too.
[2017-10-31 04:59:35] |
Yes. This is controlled through the Chart Update Interval setting on the chart itself: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
