Date/Time: Sun, 27 Sep 2026 17:36:22 +0000
[Programming Help] - ASCIL- Passing value to/from custom study
View Count: 2326
[2017-10-30 21:04:11]
vectorTrader - Posts: 86
I am working on generalizing some of my functions and I wanted to know how to pass values between 2 separate studies-
For example,
I would like to pass the output from study1 subgraph to study 2 subgraph. Study 2 would perform some manipulation on the received data and then return some output for use in study 1 to use. I know its possible, but I don't understand how to pass data back and forth and where to find more information about it.
thanks
[2017-10-30 22:19:19]
CustomIndicators - Posts: 126
How about using persistent variables?
To get/set persistent variables on studies on other charts, you can use:
https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetStudyPersistentIntFromChart
[2017-10-31 02:23:49]
I tried your suggestion by passing a value from study 1 to study 2 using the getpersistanti tfromchart. i tried to pass a value between 1 and 10 but the retrieved value just keeps growing and not changing per the study 1 function.
So I pass a sub graph instead and if so, how would I do that?
[2017-10-31 03:30:02]
To set the persistent in, did you use sc.SetStudyPersistentIntFromChart()?
There are get functions, and set functions.
[2017-10-31 03:46:29]
For local persistent ints, you use:
sc.GetPersistentInt(key);
sc.SetPersistentInt(key, newValue);
For ints on other charts, you use:
sc.GetStudyPersistentIntFromChart(chartNumber, studyID, key);
sc.SetStudyPersistentIntFromChart(chartNumber, studyID, key, newValue);
To get a subgraph from another chart, use:
SCFloatArray StudyReference;
sc.GetStudyArrayFromChartUsingID(chartNumber, targetChartStudyID, subgraphNumber, StudyReference);
float oscValue0 = StudyReference[StudyReference.GetArraySize() - 1];
That stores the current value of the subgraph into oscValue0. If you wanted the last locked value, you just increase that number 1 to number 2.
