Date/Time: Thu, 16 Jan 2025 10:40:34 +0000
bar countdown timer is lagging
View Count: 1068
[2017-10-30 20:24:40] |
User597594 - Posts: 17 |
hi, my bar countdown timer is lagging, it does not continuously count, it keeps pausing and then jumping down say 5-20 seconds
[2017-10-31 04:57:39] |
The subject is fully documented with the study here: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
