Date/Time: Thu, 16 Jan 2025 11:55:35 +0000
Cannot open trade window for a chart
View Count: 1375
[2017-10-30 20:00:50] |
amirN - Posts: 159 |
Today I am not able to open the trade window for the attached chart (most of the studies have been removed)by either CTRL_SHIFT_T or the trade window. It was working fine on Friday upgrading SC during the weekend seems to have affected it. Downgrading SC (to 1626) did not help. Please let me know what went wrong? Also when I was trading live compared to simulation the trade window was having a different background colour (Black) I seem to have lost that ability, is there any option I can select. |
Private File |
[2017-10-30 21:24:57] |
I have managed to get the trade window, it was hidden behind the windows task bar.
[2017-10-30 21:51:46] |
Use Chart >> Reset Child Windows. Also when I was trading live compared to simulation the trade window was having a different background colour (Black) I seem to have lost that ability, is there any option I can select. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-01 12:06:28] |
One further question, referring to the attached video, the last size value on the DOM sometimes come with black background, selecting something on the DOM usually clears it. Is there any setting I can change? This has been behaving this way for a very long time.
Private File |
[2017-11-01 17:51:15] |
There are six different color settings for the Last Size market data column. They are all documented starting here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Cumulative Last Size Text Bid Trade Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-01 17:52:28
[2017-11-01 19:44:24] |
Also how can I make test1 similar to test2 i.e. order box is limited only to the buy or sell column
Private File Private File |
