Date/Time: Thu, 16 Jan 2025 09:48:10 +0000
TOS Data Feed
View Count: 1023
[2017-10-30 17:44:06]
User203925 - Posts: 40
Good Afternoon SC,
Is it possible to import data from a CSV file into a study in real time to create an indicator without having to disconnect? I saw that when importing Intraday data you have to disconnect but is this referring to price data? Thanks for helping clarify this. Appreciate everything you do
[2017-10-30 18:09:59]
Yes you can certainly do this. Just write your own study to read that CSV data and do what you require with it. Refer to:
Advanced Custom Study Interface and Language (ACSIL)
Also we probably could make importing of Intraday data work even without disconnecting from the data feed. But since it is not a common operation, it is not that much of a priority.
Date Time Of Last Edit: 2017-10-30 18:10:18
[2017-10-30 18:56:53]
Thank you and thanks for the clarification here!
