Date/Time: Thu, 16 Jan 2025 11:01:28 +0000
Renko Bar Issue
View Count: 661
[2017-10-30 14:17:40] |
User12041 - Posts: 25 |
Since the most recent updates there has been an issue with the plotting of the renko bars. When plotting a 3 tick renko bar on my RTYZ7 chart today I noticed that the renko bricks occasionally shift by 1 tick causing the brick not to line up with the other renko bricks on the chart. I am using the standard renko bar set to 3 ticks with the graph draw type set to renko bricks. This has never happened in the past with renko charts. Is there something that I am doing wrong or a fix on the way ?
[2017-10-30 16:04:39] |
This is because there is price movement in this particular symbol that jumps by more than one tick. We have noticed this issue on reversal bars. We will see how to solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-31 09:46:33
[2017-10-31 09:46:07] |
This is now resolved in version 1632. Here are the instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
