Date/Time: Thu, 16 Jan 2025 09:38:18 +0000
Suggestions for fixing slow Market Depth Historical Graph
View Count: 780
[2017-10-30 12:20:38] |
Usermb - Posts: 126 |
I use the MDHG a lot, and I am very thankful to you guys for including this. I have observed it is really slow when it has to draw the quantity numbers for a chart with a lot of bars zoomed out to 0. Since only quantities displayed after the last bar are visible, would it be possible to add an option to only display these numbers? That would reduce the number of text objects by a lot. I assume this would make the study much faster, since that's the outcome when I disable the quantity numbers altogether. Another potential improvement just in case you use transparency for the levels, replacing it with solid colors only will probably help quite a bit. |
[2017-10-30 17:27:39] |
We will look into this.
