Date/Time: Thu, 16 Jan 2025 10:42:52 +0000
Data Service (CTS)
View Count: 662
[2017-10-30 07:30:31] |
joshfutures - Posts: 3 |
My trial ended over the weekend and I've been happy with sierra so I upgraded but my trial with a broker ended so I can't connect to rithmic paper trader. Will the $10 CTS data in control panel be a good replacement? |
[2017-10-30 15:25:13] |
It depends upon what you want to do. If you want real-time futures data, then the answer is no. Let us know what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-30 15:25:22
[2017-10-31 12:22:35] |
I spoke to my broker and they've carried on the trial. thank you
