Date/Time: Thu, 16 Jan 2025 10:05:12 +0000
Account Control Panel/Custom Studies Users: External Data Service Username gone!
View Count: 884
[2017-10-29 20:55:53] |
binaryduke - Posts: 373 |
As of 29/10/17 c.2000h CET, the External Data Service username field has disappeared from the Account Control Panel/Custom Studies User Access management!
[2017-10-29 21:33:41] |
It is no longer needed. Have the user update to the current version: Software Download: Fast Update And have them give you the account Name under Help >> About within their copy of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-29 21:56:03] |
OK. How about existing Transact user IDs? Do they need to be transitioned?
[2017-10-29 22:03:04] |
No. As you can see they are still there.
