Date/Time: Thu, 16 Jan 2025 13:17:21 +0000
s_UseTool LineStyle, LineWidth and Color not adjusting Price Retracement ACSIL Drawings
View Count: 1010
[2017-10-29 15:12:46] |
kas64h - Posts: 87 |
Hello, When inserting a new Price Retracement drawing using ACSIL, I successfully set the Price Retracement baseline (the line linking the start and end anchors), properties: Style, Width and Color, using the s_UseTool members LineStyle, LineWidth and Color respectively. However if I use these same ACSIL s_UseTool members to try and ADJUST the same Price Retracement baseline properties, the changes do not take affect. I'm using the AddMethod 'UTAM_ADD_OR_ADJUST' (as I do with any other drawing I want to adjust), and I know the adjustment is 'successful' - it's just the changes are not appearing on the actual chart drawing. I say the adjustments are 'successful' because if I change some of the Retracement Level properties on the same pass (i.e. LevelColor[] for example), they DO successfully render, it's just these Price Retracement baseline properties that do NOT. Any help much appreciated. Many Thanks |
[2017-10-31 17:49:07] |
We are looking into this.
[2017-11-09 11:59:00] |
Was wondering what the latest was on this issue. My only reason for asking is that I noticed with the release of the latest version (1635), the Color property mentioned above now renders correctly on adjustment, whereas LineStyle and LineWidth still do not. Just seemed a little unusual, hence the query. Many thanks |
