Date/Time: Sun, 24 Nov 2024 03:04:25 +0000
Using Sierra chart in two separate PC's
View Count: 1631
[2013-09-11 10:19:41] |
katek - Posts: 28 |
Hello, I used to have Sierra Charts running in two machines (using the same license). I believe we could have it running in up to 5 machines at the same time. Is not the case any more? Do we need now one license for each machine? |
[2013-09-11 10:24:36] |
You can use Sierra Chart on up to 2 computers at a time. With package 5 you can use Sierra Chart on three systems.
[2013-09-11 22:13:41] |
katek - Posts: 28 |
Hi, For some reason when I log-in on sierra chart on the second machine, the sierra charts stops updating the data. The following is the message log: Message from IB: Market data farm connection is broken:usfuture.us. IB Error Code: 2103. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is broken:cafarm. IB Error Code: 2103. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is broken:usfarm. IB Error Code: 2103. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: HMDS data farm connection is broken:ilhmds. IB Error Code: 2105. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market depth data has been RESET. Please empty deep book contents before applying any new entries.. IB Error Code: 317. Request ID: 100002. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is OK:cafarm. IB Error Code: 2104. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-09-11 18:04:42 Message from IB: HMDS data farm connection is inactive but should be available upon demand.ilhmds. IB Error Code: 2107. Request ID: -1. | 2013-09-11 18:10:42 |
[2013-09-11 23:13:28] |
These are all messages from Interactive Brokers. However, we see nothing unusual about them. Refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
