Date/Time: Thu, 16 Jan 2025 09:55:29 +0000
Destroy Chart Windows When Hidden Doesn't Work
View Count: 1384
[2017-10-28 19:55:59]
User948528 - Posts: 108
1. Including up to v1630 PreRelease, while all CB's closed, set Destroy Chart Windows while Hidden, open CB's, can not switch between CB's, only one CB remains visible.
2. When this feature is functioning correctly, will prices continue updating/alerts activating on Hidden CB's?
[2017-10-28 20:29:13]
1. We do not observe any problems with this functionality at all. Therefore, if you are having a problem with it in your case, do not use this option.
We do not know what the problem is in your case and cannot spend any time on it.
2. Yes.
Date Time Of Last Edit: 2017-10-28 20:30:33
[2017-10-30 02:52:44]
I've found the problem, it occurs with the Window Always Visible option on the chartbooks enabled. With Destroy Chart Windows When Hidden also enabled, can no longer switch from one visible chartbook to another on top of it.
Can Window Always Visible feature work correctly with Destroy Chart Windows When Hidden? This would allow being able to work with multiple chartbooks open on top of each other (some), switch between them, and conserve resources.
Date Time Of Last Edit: 2017-10-30 13:48:40
[2017-10-30 18:12:27]
This is not clear for us.
We did testing using Window Always Visible for a chart and switched between Chartbooks when using Destroy Chart Windows When Hidden and see no problems.
