Date/Time: Thu, 16 Jan 2025 09:52:39 +0000
How fix the blurry text in DOM
View Count: 1054
[2017-10-28 18:06:26] |
User197449 - Posts: 2 |
hello everyone I'm from Poland My question is how fix the blurry text in DOM |
Bez tytułu2.jpg / V - Attached On 2017-10-28 18:01:23 UTC - Size: 261.71 KB - 323 views Attachment Deleted. |
[2017-10-29 13:00:03] |
Update to the current version of Sierra Chart: Software Download: Fast Update And use this setting: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-29 14:31:00] |
Thank you very much..it's works
