Date/Time: Thu, 16 Jan 2025 09:59:46 +0000
zig zag question
View Count: 1278
[2017-10-28 04:58:38] |
User99934 - Posts: 227 |
On zig zag study, I do not understand "Display ZigZag Volume / Tick Size (ln:36)" Also, on earlier version, didn't you have a ratio of volume to time? |
[2017-10-29 05:38:04] |
This has been changed to divide the zig zag volume across the zig zag line by the length of the line in ticks but it was not properly implemented. Dividing purely by the tick size makes no sense. We apologize for that. We will fix this in the next release coming out in a day. Also, on earlier version, didn't you have a ratio of volume to time? No. Not sure how that would be calculated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-29 05:41:40
