Date/Time: Sat, 26 Apr 2025 09:39:08 +0000
CTS Connection Errors
View Count: 1590
[2017-10-27 19:20:04] |
User948528 - Posts: 108 |
Using CTS directly through Amp, I am still getting two different connection errors resulting in sporadic disconnections, the errors are below: 1. CTS FIX socket (6) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-10-24 10:59:43 CTS FIX socket (6) | Initiating close of socket by core. | 2017-10-24 10:59:43 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-24 10:59:43 CTS FIX socket (6) | Shutdown started. Waiting for graceful close. | 2017-10-24 10:59:43 Connection to the external service has been lost. | 2017-10-24 10:59:43 CTS FIX socket (6) | Received socket Close event. | 2017-10-24 10:59:43 CTS FIX socket (6) | Still waiting for graceful close or receive error. | 2017-10-24 10:59:43 CTS T4 FIX | Disconnected. | 2017-10-24 10:59:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-24 10:59:45 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-24 10:59:49 CTS T4 FIX | Firm: AMP | 2017-10-24 10:59:49 CTS FIX socket (140) | Creating socket. Using TLS 1.0. | 2017-10-24 10:59:50 CTS FIX socket (140) | Connecting to IP: 208.116.215.102. | 2017-10-24 10:59:50 CTS FIX: Sending the Logon message. | 2017-10-24 10:59:51 CTS T4 FIX | FIX version: 4.7.1.0 | 2017-10-24 10:59:52 CTS T4 FIX | Connected to data and trading server. | 2017-10-24 10:59:52 CTS T4 FIX | Starting real-time market data updates for: NGJ7-NYMEX. ID: 1 | 2017-10-24 10:59:52 Symbol Error - NGJ7-NYMEX is unknown, unavailable, or improperly formatted. CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: NGJ7-NYMEX | 2017-10-24 10:59:52 2. HTTP connection to ds01.ddfplus.com:80 (21) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-25 03:30:41 * 3. The symbol format error, is from the old previous feed (Rithmic), not using any charts with the old formatting, not sure where it's still being used in SC, cleared everywhere I can find, how do I get rid of it? |
[2017-10-27 19:37:21] |
It sounds like you have an Internet connectivity problem especially being you are experiencing 2. That really should not be commonly encountered at all. Refer to: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem Regarding the "encryption stream error" encountered, we will see if there is anything we can do on our side related to that. 3. Refer to: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-27 19:43:08
[2017-10-27 20:05:10] |
#1. This the main error causing the disconnect, am on a Verizon FIOS 150Mbps fiber optic connection that is stable and other than this issue seems to experience zero down time ever, never had any connectivity issues in other use or other feeds. Sierrachart has been allowed in the Windows firewall rules and SC and feed connect fine, after some time randomly and rarely disconnects with the two errors above at different sporadic times. #2. This seems to be on the other side? Please let me know if there is anything I can do to help trouble shoot or resolve from my side. Date Time Of Last Edit: 2017-10-27 20:17:59
[2017-10-27 20:58:04] |
1. We are currently looking into this to see if it is an issue on our side for TLS connections. It might be. We will let you know if we need anything more. 2. Possibly. But it is not very common. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 21:37:31] |
1. In the next release, there will be additional logging to help us identify this problem further. This will be out in about a day. At this point we are suspecting it is a problem within Open SSL which we use. Just looking at the problem directly without consideration to external errors or mistakes, that is what it would appear to be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 23:59:55] |
We have released version 1630. We want you to update to that version: Software Download: Fast Update Good chance it may solve the problem. If it does, it does clearly indicate that this is an Open SSL issue that we have to report to them assuming we are properly understanding it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
