Date/Time: Tue, 28 Jan 2025 14:03:06 +0000
NG Nov Data Missing on Dec Continous Chart - CTS, SC v1628
View Count: 1096
[2017-10-27 16:03:43]
User948528 - Posts: 108
Charting NG Dec contract on CTS, SC v1628, on continuous chart, Nov data is missing. Tried all methods of reloading, Delete and re-download, and deleting daily files does not fix.
Charting Nov contract works fine.
NG.20171200.CME_NY [CBV] Daily #12 | Error while getting daily open price with date 2017-10-27 from file. C:\SierraChartCTS\Data\NG.20171200.CME_NY.dly. Error: Date not found | 2017-10-25 03:40:08
Unable to determine transition date based on volume from files: NGX17.dly, NG.20171200.CME_NY.dly | 2017-10-25 03:45:19
The NG.20171200.CME_NY.dly symbol may not be the active contract month. | 2017-10-25 03:45:19
Date Time Of Last Edit: 2017-10-27 19:08:36
[2017-10-27 19:08:04]
Follow the instructions here:
The Historical Daily chart looks good for us:
http://www.sierrachart.com/image.php?Image=1509131246783.png
We also verified the CTS Symbol Settings. So you should get the same result when using CTS as well.
[2017-10-27 22:16:07]
Thanks this fixed it, but I'm still struggling with this error on a different symbol, GC:
GC.20171200.CME_CO [CBV] 60 Min #4 | File GCQ17.dly has a price inaccuracy at Date: 2017-07-27. Price: 12600 is significantly off compared to next contract open price of 1275.3 | 2017-10-27 18:06:43
It was two different similar errors before, I've tried deleting and re-downloading all the recent GC contract daily files, and still have the one error above. Is it related to old historical data files being from a different feed/format?
Date Time Of Last Edit: 2017-10-27 22:16:28
[2017-10-27 23:08:20]
If you follow this procedure here:
And re-download data for all contract months, you should not encounter that error anymore.
