Date/Time: Sun, 24 Nov 2024 02:34:15 +0000
Error Conection to IQFeed
View Count: 1650
[2013-09-11 06:28:42] |
sts - Posts: 9 |
I can't connect to IQFeed, there is no Login/Password dialog. Message in log: IQ Feed: Connecting. | 2013-09-11 10:18:28 Starting DTN IQ Feed interface software. | 2013-09-11 10:18:28 Error starting IQ Feed interface software. Error code: 2 | 2013-09-11 10:18:28 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-09-11 10:18:28 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-11 10:18:28 To prevent further connection attempts, select File >> Disconnect. | 2013-09-11 10:18:28 IQ Feed: Fully disconnected. | 2013-09-11 10:18:28 |
[2013-09-11 07:10:10] |
It appears that you do not have the IQ Feed software installed. Please install it here: http://www.iqfeed.net/iqfeed_client_5_1_0_5.exe?FixforIE=.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
