Date/Time: Thu, 16 Jan 2025 09:42:50 +0000
Issue with Percent change since previous close study
View Count: 840
[2017-10-27 13:01:18]
Kinobe - Posts: 86
hi
I ve just updating Sierrachart today and I can t get anymore the right value for the percent change since previous close.
before updating, the value in the quoteboard and the value on the graph was the same - see picture. I did not change anything except updating.
the last update was 1 month ago.
thank you.
imageIssue_%change.jpg / V - Attached On 2017-10-27 13:00:34 UTC - Size: 432.33 KB - 385 views
[2017-10-27 16:04:56]
nioko54130 - Posts: 108
same issue with 1629
[2017-10-27 18:34:50]
The percentage is stored where 1% is .01.
It displays properly when using the Percent Value Format.
The problem is, is that you are making reference to it by another study. So you will want to use Study Subgraph Multiply:
