Date/Time: Thu, 16 Jan 2025 09:56:26 +0000
change drawings from other charts
View Count: 791
[2017-10-27 12:55:29] |
AKR - Posts: 523 |
when a drawing from an other chart is changed in the actual chart used and then you right click and make undo then unfortunately not the last change is undone but the last change from a drawing that was made in that chart. so I then often need to search in which chart is the drawing I had changed to be able to undo (as I link 3-4 charts together and draw and change in all of them). would be great if just the last change would be undone independent of where the drawing was orginaly made. |
[2017-10-27 18:38:15] |
The undo limitation is documented here: Chart Drawing Tools: Modifying and Deleting Drawing Copied to Other Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
