Date/Time: Thu, 16 Jan 2025 09:56:41 +0000
Range Bars not displaying correct number of ticks
View Count: 733
[2017-10-27 12:20:56] |
samual sprat - Posts: 343 |
Hi, I've setup a chart with 365 days of data load, with bar period type of Range Per Bar Standard (in ticks) and 200 tick bars. I'm finding that there are many instances of bars which are far less than 200 ticks, they don't go above 200 ticks though. This happens on all symbols i've tried regardless of price display format, tick size and graph draw type. Any idea why such small bars may be printing? Thanks S Date Time Of Last Edit: 2017-10-27 12:23:45
[2017-10-27 17:29:11] |
This is explained here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Standard (in ticks) (Chart >> Chart Settings menu) It relates to New Bar at Session Start. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 18:05:06] |
How embarrassing, I've been using it like this for weeks now! Looks completely different - Thank you :D
