Date/Time: Tue, 28 Jan 2025 14:03:02 +0000
Filtering intraday data for specific weekdays
View Count: 918
[2017-10-27 12:15:04] |
User335535 - Posts: 1 |
Hi All , I am trying to filter ES intraday continuous futures chart for a specific day , ie say Friday's only. So at the end I would like to see only 5 minute charts for Friday's only in a particular period. Please let me know if it's possible to do. thanks |
[2017-10-27 18:31:11] |
The best you can do is use this setting in Chart Settings: Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
