Date/Time: Wed, 29 Jan 2025 21:56:46 +0000
[User Discussion] - bid/ask price tags on Y-axis ?
View Count: 1718
[2017-10-27 09:51:19] |
Napoleon Dynamite2 - Posts: 16 |
Hi, The last price has its tag in white on the Y-axis. Unfortunately, on CFD/forex, having the avg bid-ask is about useless since this price has no real useful meaning to trade it. I have used the “Draw DOM graph on chart” feature and enabled to show bid-ask prices but those numbers sometimes resize badly and overlay the candles when the chart is being scaled out despite fixing a large locked space on the right of the chart. Also, that display of floating numbers distracts me somehow. I am wondering, is it possible to hide the last price tag in white, and instead have the bid and ask prices show as similar tags (color editable) directly on the Y-axis (which never runs into rescaling troubles) ? Illustrated screenshots attached Date Time Of Last Edit: 2017-10-27 09:51:35
EC7E48D9-6337-4DC7-9A9A-081FFBFA1CE7.png / V - Attached On 2017-10-27 09:38:25 UTC - Size: 804.82 KB - 404 views Private File |
[2017-10-27 18:49:10] |
This does not make sense to us: I have used the “Draw DOM graph on chart” feature and enabled to show bid-ask prices but those numbers sometimes resize badly
These should be completely stable. They do not resize. Also, this is the study you want to use to do what you want: Bid & Ask Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-27 18:49:36
[2017-10-28 01:05:55] |
Thanks. But is there a way to hide completely the last price price box ?
[2017-10-28 02:23:59] |
No.
[2017-10-28 12:35:30] |
Then, is there a way so that the Z-order of the price boxes from the Bid/Ask prices study becomes above (in front of) the last price box ? Or maybe set the last price box to be transparent ? Date Time Of Last Edit: 2017-11-04 17:17:55
[2017-11-04 17:18:06] |
Up
