Date/Time: Thu, 16 Jan 2025 10:07:56 +0000
VWAP not resetting on current day
View Count: 1152
[2017-10-27 09:49:32] |
User464702 - Posts: 18 |
VWAP not resetting on current day. It resets at the start of the session as required for past days but not current. "Use evening session" is off and I have tried resetting is. But this has not changed anything. http://www.sierrachart.com/image.php?Image=1509097387706.png I have attached screen shots using the method asked for and screen shots to show current settings |
[2017-10-27 19:27:17] |
Give us about one week to look into this.
[2017-10-30 02:13:04] |
We have looked into this, and as we have expected, there is not a problem within the study itself. You are using an Australian time zone, and the last day of the week, based on the reversed Session Times you are using, is considered Saturday. Since you have the the Exclude Weekends Input set to Yes, there is no reset on Saturday. So you need to set that Input to No. Or do not use an Australian time zone of the chart. We will update the documentation regarding this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-30 02:13:37
