Date/Time: Thu, 16 Jan 2025 10:02:02 +0000
Trader DOM Last Size could not be seen
View Count: 868
[2017-10-27 07:57:26] |
rc7rader - Posts: 144 |
In Graphic Settings - Global, I set the colors for the Trader DOM. I had text and background different colors so I could see the text. However, in the last size column, I noticed that in some instances, both the last size text and background are both white so I could not see the text. Any idea what is causing this? I have attached a screenshot to show the issue. Thanks. |
TraderDOMlastsizeBlank.jpg / V - Attached On 2017-10-27 07:52:47 UTC - Size: 52.43 KB - 309 views |
[2017-10-27 19:27:46] |
We added a paragraph to the documentation for the associated color setting here which explains this: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Cumulative Last Size Text Bid Trade There are actually 6 color settings for the market data column Last Size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-27 19:28:12
[2017-10-30 19:08:24] |
I don't understand why you have to put this four seconds rule.
This was something requested and insisted upon by some users. Does not really make sense to us. Now we have to add an option to remove it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
