Date/Time: Thu, 16 Jan 2025 09:55:09 +0000
Standard Deviation Indicator?
View Count: 2727
[2017-10-26 23:21:36]
User341752 - Posts: 26
I came across your SD indicator and I'm trying to find out how it works. Is it calculated from the 68, 95, or 99.7? And how could I calculate it so I can find the other 2 and 3 deviations. All I see is input in the study settings, which I'm not sure how its related to the concept.
If you can shed any light on this it will be helpful
[2017-10-27 04:51:08]
The study is fully documented here:
Standard Deviation
It does not involve any fixed constants at all. It is simply a standard deviation.
You may also want to use it with the Arithmetic Studies:
Using the Basic Arithmetic Studies
