Date/Time: Thu, 16 Jan 2025 10:03:11 +0000
Stop -limit
View Count: 893
[2017-10-26 15:35:10] |
User93731 - Posts: 83 |
Hi: I use the bracket (Parent, target and Stop) and enter stop order on DOW. Today, it was filled at market and three ticks hiehr than i want . How could I set my parent order at Stop-limit for my bracket order and still allow me to ckick on DOW to enter the order? thanks |
[2017-10-26 17:52:57] |
You just set the Attached Stop Order to be a Stop-Limit order. Here are the detailed instructions: Attached Orders: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 14:06:57] |
Hi: I want my parent order to be stop-limit, not for attached stop in my bracket. Currently, when I click on DOM and place a STOP parent order, it showed my parent order as STOP. I want to set this default as STOP-Limit, without go to use "Trade Window" and insert a "stop-limit" price on this window. It took too much time and effort. I want it to be "One-click" on my DOM. Is this function avaialble now? Thanks. |
[2017-10-27 20:34:29] |
In this case, then you need to configure the Chart DOM to use Stop-Limit orders and this is documented here: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 22:55:41] |
Hi there: Thank you for the information. However, when I go to this Gobal setting for my COM setting . I did not see the availability of "stop- limit" or "Buy Market if Touched" For Example: Order Input above Last Left click on bid price limit above last. I could only choose among "Ignore Input", "Buy Limit" and "Buy Stop" ================================================ My Version is 1382 and I have package of level 3. If I update my version, Will it solve my problem? Thank you for your help. |
[2017-10-27 23:10:20] |
You are running an older version of Sierra Chart. You must update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 23:51:56] |
Dear There: Thank you for the fast reply. I updated it and I oculd see the stop limit now. Thank you. |
