Date/Time: Thu, 16 Jan 2025 09:49:19 +0000
can we customize the MENU bar to include time periods 30sec and 15sec
View Count: 1561
[2017-10-26 13:50:25]
bala - Posts: 74
Currently I can see only 1min as the lowest value from the menu . For 30 sec I have to go to the chart settings. Can I customize the menu to include 30 sec and 15 sec?
[2017-10-26 15:02:09]
Xfanman1 - Posts: 320
Add a Custom Time Period Button to your menu. See the images below but right click on the menu bar and select Customize Control Bar. Then add your settings by selecting the Custom Time Period, modify it to your timeframe and then label it by changing the button properties as shown.
image30 Second Button.PNG / V - Attached On 2017-10-26 14:58:57 UTC - Size: 28.76 KB - 383 views
imageCustom Bar Period.PNG / V - Attached On 2017-10-26 14:59:27 UTC - Size: 31.79 KB - 379 views
imageSet Time Period.PNG / V - Attached On 2017-10-26 14:59:46 UTC - Size: 35.01 KB - 363 views
imageButton Properties.PNG / V - Attached On 2017-10-26 15:00:15 UTC - Size: 39.4 KB - 337 views
imageMenu Bar.PNG / V - Attached On 2017-10-26 15:02:01 UTC - Size: 4.61 KB - 340 views
[2017-10-26 17:59:26]
You cannot customize the menu but you can add your own custom Control Bar buttons for time periods:
Control Bar: Custom Buttons for Intraday Chart Bar Period
That is very good of you to provide those screenshots in post #2, but Sierra Chart already has complete documentation for this.
