Date/Time: Thu, 16 Jan 2025 09:56:23 +0000
Detach/Attach Window don`t Function
View Count: 747
[2017-10-26 11:03:59] |
tomtr27 - Posts: 22 |
With the Chart evacuate, freezes of the Hauptchart. The evacuated window functions perfectly. When I have integrated the window again functioned Sierra as usual. Rev in 1629 |
[2017-10-26 17:14:30] |
We tested detaching a chart in version 1629 and do not see a problem. Is also not completely clear what you are describing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
