Date/Time: Thu, 16 Jan 2025 09:41:11 +0000
usdjpy
View Count: 937
[2017-10-26 10:55:30] |
TheFibber - Posts: 83 |
sorry i think there is a problem with your sc forex data usdjpy...
[2017-10-26 11:07:51] |
We do not observe any problem with the data for this symbol. What is the problem you are having?
[2017-10-26 14:11:49] |
there was an error with name..there was natural gas and then all the delivery dates to choose from..i updated the version of sc and now it is ok thanks |
[2017-10-26 17:04:18] |
Updating the version of Sierra Chart would not change anything in regards to this.
