Date/Time: Fri, 11 Sep 2026 05:07:08 +0000
Text windows for market news
View Count: 1329
| [2017-10-26 08:27:13] |
| User741077 - Posts: 1 |
I would like to suggest the addition ( or modification of an existing one ) tool. Sometimes a move in the market is caused by a very specific piece of news. I miss having the possibility of attaching a marker-label-whatever to the chart which when clicked upon shows a text window with a few lines explaining the situation. The current text tool is not suitable for such purpose for it clogs the chart very quickly with text that I don't necessarily want to have visible at all times, but only when I decide so. Such a tool would make my life easier with keeping market reports handily linked to the instrument I'm trading. I would appreciate if your development team could consider adding this feature in the builds to come and I don't want to miss the opportunity to thank you all for the wonderful piece of software Sierra Chart is. |
| [2017-10-26 18:32:42] |
Something like this eventually will come.
| [2019-09-13 07:42:13] |
| Mattthespaniard - Posts: 42 |
I take the opportunity to insist on the suggestion I made 2 years ago. This feature is one of those tools that don't seem like much but actually make trading life much easier. Please consider. By the way, this new service of yours "SC futures order routing through TT" works great. I'm very pleased. Thank you. |
