Date/Time: Wed, 27 Nov 2024 16:55:45 +0000
Chart Settings Vertical Grid Lines
View Count: 4377
[2017-10-26 08:25:13] |
User787778 - Posts: 140 |
Is there a way to change the line settings for "Chart Settings Vertical Grid Lines" as they are difficult to see on a light coloured chart background? A Time Line Study that draws a line every "X", would also do the job. Thanks in advance |
[2017-10-26 18:32:21] |
Yes, refer to: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
