Date/Time: Thu, 16 Jan 2025 08:55:34 +0000
Charting 2 Year Yields
View Count: 826
[2017-10-26 03:29:31] |
User841161 - Posts: 230 |
Can a spreadsheet data be imported into sierra charts and then charted.
Private File |
[2017-10-26 04:12:27] |
The data needs to be in a text CSV format. Refer to: Text/CSV Data Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-26 04:12:35
