Date/Time: Thu, 16 Jan 2025 08:11:04 +0000
Showing Imbalance on Numbers Bar
View Count: 9314
[2017-10-25 19:36:01] |
User172040 - Posts: 70 |
Hi, I am trying to configure the numbers bar study to show imbalances on the bid and ask price levels. I've set my 'Column 1 Text Coloring method' to 'Based on Diagonal Dominant Side AskVol BidVol Percentage' and then I set my 'Column 1 Percent Compare Thresholds' to 3,3,3 (300%). So if the ask volume exceed the diagonal bid volume with 300% it should highlight that volume in the bar with a green color and when vice versa the color should be red. However, it seems like all my levels are highlighted irrespective of % threshold. Can you lead me in the right direction please? PS - Column 1 Numbers Bars Text = Bid Vol x Ask Vol |
Imbalance.PNG / V - Attached On 2017-10-25 19:35:54 UTC - Size: 64.43 KB - 2366 views |
[2017-10-26 07:37:39] |
http://www.sierrachart.com/image.php?Image=1508999276429.png Herewith a screenshot as per your instructions |
[2017-10-26 18:26:26] |
Here is the documentation for that text Coloring Method: Numbers Bars: Text Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage There must be a problem with the Color Settings. They should not all be the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-26 18:31:56] |
We also realize there is a small mistake in the documentation we are correcting. We are also verifying if the Default Text Color is still used or there is always a mapping to the 8 Up and Down Color settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-27 05:40:50] |
Set: 'Column 1 Percent Compare Thresholds' to 0, 0, 3 Set the Range 3 colors to the colors that you want. The other color settings need to be a neutral color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-17 01:09:27] |
User592026 - Posts: 7 |
would it be possible to get a template for this setup? Thanks in advance
[2018-12-19 17:55:50] |
Would be best that you just refer to the documentation here for Numbers Bars: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-07 11:09:13] |
User735587 - Posts: 21 |
Is it possible to make the numbers bold and change the size just for the imbalances related to the Range 3 ? Thanks |
