Date/Time: Thu, 16 Jan 2025 08:56:27 +0000
Numbers Bar Separator Thin Candlestick Option
View Count: 1969
[2017-10-25 17:16:41] |
BenjaminR - Posts: 170 |
I want to complicate your life further by requesting a Numbers Bar Study separator that is a thin candlestick (see example attached). Thank you for it's consideration. (I tried a workaround by doing a study overlay of Numbers bars to a candlestick chart of the same instrument, and nothing happened). |
Sample Candle Separator.PNG / V - Attached On 2017-10-25 17:13:53 UTC - Size: 91.2 KB - 1262 views |
[2017-10-25 19:04:34] |
binaryduke - Posts: 373 |
You can overlay a candlestick chart using Price/Study Overlay to your main numbers bars chart to achieve this and set the candlestick width to something low eg 10-20% ie the opposite to what your overlay approach was.
