Date/Time: Thu, 16 Jan 2025 09:03:40 +0000
Chart Dom Column - % pnl
View Count: 975
[2017-10-25 15:48:54] |
knoxville1915 - Posts: 38 |
Is it possible to create a chart dom column that shows P&L in terms of Percent? Thanks! |
[2017-10-25 18:15:27] |
No. That is not supported. How would that be calculated? Percentage of what?
[2017-10-25 18:24:20] |
(sc.Close[sc.Index] - PositionData.AveragePrice) / PositionData.AveragePrice * 100
