Date/Time: Thu, 16 Jan 2025 08:49:58 +0000
Sort Trades by Exit Strategy
View Count: 930
[2017-10-25 15:46:35] |
User993067 - Posts: 156 |
Is there a setting under the trading activity log to sort trades by exit strategy for comparison and analysis?
[2017-10-25 18:16:23] |
Are you referring to the new "Note" field? You can only filter by that field by selecting a particular note from the Note drop-down list at the top. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-25 18:58:19] |
i do not see Note from a drop down list...I am referring to trade window configuration files...I want to analyze efficacy of different exit strategies created...different targets & stop configurations..produce different results..need to see what is working...can only view entirety of trades taken cannot breakdown by strategy.
[2017-10-25 19:03:21] |
Update Sierra Chart to the current version. We will document the new Text Tag and Note fields. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
