Date/Time: Thu, 16 Jan 2025 08:56:27 +0000
Trading on Bitmex while viewing feeds from other exchanges
View Count: 864
[2017-10-25 14:57:49] |
User273916 - Posts: 6 |
I trade on Bitmex. I also follow the markets of Bitfinex and Bitstamp to help make my trading decisions. I can get data feeds for all three exchanges at the same time through the "Cryptocurrencies Data - DTC" feed, but then I cannot trade. Is it possible to trade on Bitmex through Sierra Chart while also displaying charts from Bitfinex and Bitstamp? If not at the moment, can this be implemented in the future?
[2017-10-25 17:35:55] |
You need to install another copy of Sierra Chart to use with the "Cryptocurrencies Data - DTC" Service. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-25 17:39:04] |
Do you intend to change that in the future? It is a hassle to have to run two instances of Sierra Chart to get the functionality I need.
[2017-10-25 17:55:02] |
Probably not because it inevitably will create confusion. Where someone thinks they can trade a symbol from another exchange within the same instance of Sierra Chart. We do not think using two instances is a hassle. That is very easy. You also have the ability to share chart data among them. Refer to: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-25 17:56:28
